hi came sto starting my gt after a month and its now sat outside, just got click click click, thought batt waflat so hooked jump leads up and still same, gave starter a tap and still no joy, then checked the plug under swirl pot, see if water had got in it, sprayed wd on it and still no joy,some one before me had put copper grease all over the connectors.(is this bad will it connect electricity through the different coloured wires). so anyway left it a god ten mins with jump leads on from my running van, came back to it and click click click then it started, leftt it running a good 15 mins with leads off van got engine warm, turned engine off and tried to start it again, got click click click again and after a few attempts would start to fire the engine but not start then click click then wud try and start and after a few times will start, so do you guys think this is the starter sticking or the wiring, or is there a starter relay somewhere that could be wet or faulty? thanks
