Results 1 to 14 of 14
    walsall
    god dam renault heeeeelp
    where to start engine was running fine then it started as if it was running on 3 so i changed the carb and it sorted the problem out then its started again so ianm came round tryed his carb ,we changed the dizzy ,plugs leads ,tdc lead , plugs , still running and missing but runs fine on tick over just misses when reving ive now taken the head off and conrods must be ok as piston hit highest point at same time so rods are not bent , push rods are straight tappets are good ???? comp test gave me 135 to 140 across all 4 with plug in and plugs out with acc on and also tryed with it off its doing my head in
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Re: god dam renault heeeeelp
    test for leaks inlet mainfold etc...
    walsall
    im changing it tomoz as the head is off so hoping someone can points somethink else while stuff is apart
    Wickford
    Hey mate, I had similar issues last year. Turned out to be the tdc sensor wire.
    Only really played up on damp mornings, so kinda intermittent .
    Hope u sort it
    walsall
    ok update.... ive changed the inlet and exhaust manifolds and gasket, aei, vac pipe from aei to carb rebuilt and then did a comp test and again 135 - 140 across all 4 pistons . still missing on revs
    ive changed the tdc leads disconnected the knock sensor,
    any idea's guys im ready to put the match to the bloody thing
    Non-member Slim's Avatar
    Sep 2009
    NW London
    I had a funny missfire at 2500rpm.. turned out to be the main HT lead.
    walsall
    tryed another one no change
    its blowing loads of black soot and running on 3 once revs are picked up from idle
    Non-member IANMM's Avatar
    Sedgley
    so after listening to all my advice what was the out come mate...?????
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    Sounds like the coil possibly? try another aei.
    walsall
    Quote Originally Posted by IANMM View Post
    hows your window mine works
    walsall
    fixed the problem i hope
    items changed
    aei
    plugs
    dizzy
    leads
    tappet rail
    head gasket
    inlet manifold
    exhaust manifold
    gaskets
    rebuilt carb bit by bit
    replaced jets ect
    blown down fuel line ( incase of blockage )
    used petrol no plugs in and turned engine pouring petrol down inlet port incase of blockage
    so im hoping its all working again
    id like to thank sparkie , my gf, the weather , sun light , the angle of my drive way for draining water and fuel away , my work for the phone i used , ow ya almost forgot ianmm
    Sedgley
    Quote Originally Posted by bye_all_c_ya View Post
    yeah my really smart 16 yr old son.....how dare he whind down the passenger window.....does he not know it sticks....lol
    Sedgley
    items changed
    aei
    plugs
    dizzy
    leads
    tappet rail
    head gasket
    inlet manifold
    exhaust manifold
    gaskets
    replaced jets ect
    you need to erect a shrine too me i think
    i still think your G/F is messing with your car at night just so i have too pop around
    walsall
    i think you mess with my car so you can come round ( my cooking was ok maybe thats it ? is it shopping week again already?
