Results 1 to 7 of 7
    Jan 2010
    north devon
    Throttle cable
    hi guy's on my renault conversion with a volvo i was wounerding what throttle cable i can use, i'm i able to use a universal cable or a paticuler cable i should ask for?
    Plus do i need to change any thing to drive shaft as i'm having trouble with the drive shaft on drivers side when trying to fit it in?
    Thanks
    jose
    Non-member philg's Avatar
    Aug 2009
    Newcastle
    Re: Throttle cable
    i used a gt cable and gt drive shafts on by b18ft conversion as do many others
    Non-member sieger's Avatar
    assen city
    Re: Throttle cable
    i use an unversal cable from a moped :P
    Jan 2010
    north devon
    Re: Throttle cable
    Thanks mate but mine looks abit short tho and i'm not sure if i should i buy i new throttle cable for the renault 5 GTT because i have dalts that it won't be long anough plus on the renault and the volvo the cables are different at the ends.
    Non-member REGGY5GT's Avatar
    Nov 2009
    shropshire
    Re: Throttle cable
    i bought a universal gtt cable from cgb as its plenty long enough and modded it to fit on the throttle bodie end, looped it round the throttle and used a couple of wiring block connectors as stops.
    Non-member dave r5's Avatar
    Aug 2009
    pitsea essex
    Re: Throttle cable
    I used a a standard cable but the nipple that normally goes in the throttle pedal end is now in the throttle body.
    I then used an old style push bike bull dog brake wire clamp at the pedal end.
    Hope that makes sence
    Jan 2010
    north devon
    Re: Throttle cable
    thanks guy's for the help all sorted now
