Results 1 to 26 of 26
    Non-member Slim's Avatar
    Sep 2009
    NW London
    T28 turbos and 1st gear
    I have hardly any boost in 1st gear which is quite depressing... is this normal with all t28s?? i also have 285 cam..
    Non-member IANMM's Avatar
    Sedgley
    Re: T28 turbos and 1st gear
    T28 wont boost until late prob 4.5k ish if not later
    Sep 2009
    NW London
    Quote Originally Posted by IANMM View Post
    ye i thought as much.. but my first gear is literally like a normal car lol.. crappp!! i put a machined out t2 .35 exaust housing which i havent found has helped much. Im thinking of putting my other housing back... but in 2 minds.
    what would be better... a machined out t2 .35 or t25 .49 with custom elbow (enlarged i guess)
    Non-member rs250nut's Avatar
    What sort of t28 is it? What are the sizes of the wheels? Is it journal bearing or roller bearing? My old t28 rb worked a treat full boost around 4000rpm. I would not bother with a exhaust housing smaller than a .49
    Sedgley
    you got a rev limiter?
    advance ign by 4 degrees doing the tdc swap (make it feel more responsive)
    and clutch it i had a T28 once just used to clutch it all the time really you can take it up to 6.5k on the revs no prob as your cam will be cutting in from 3.7-7k (if memory serves me right)
    Sedgley
    big turbo = big lag but big boost
    smaller turbo = less lag but not as much big boost....
    up to you
    i always found a good T25 to be the happy medium (but my VNT rocks )
    How can you tell him to advance up the ignition when you dont know what sort of boost he is running
    Non-member Biggs's Avatar
    My house
    Slim,whilst out on my travels, i saw your car parked up on your drive today.
    It looks nice and clean.... so does the red on a couple of doors down.
    Sep 2009
    NW London
    im not sure.. adam L has rebuilt it.. so im sure he knows... i should get to know really :P it was one from mike along time ago.. had a saab rear end tho (ex housing) thats all i know.. I think i may be putting the .49 rear housing on again..
    Sep 2009
    NW London
    lol good point! .. i dnt wana tounch the ignition timing or watever.. last time i did that.. i blew the head gasket.. :P
    Sedgley
    if he is running a new turbo im sure he wont be running anything stupid......
    but anyways....
    what boost you running mate?
    Sedgley
    oh and i take it your fuling is ok to run whatever boost your running>?
    but anyways....
    Why would he not be running alot, I banged mine on went straight out testing at 24psi? Take into consideration comp ratio, fuel type, boost etc before telling someone to wind on the ignition or it will all end in tears......
    Sedgley
    well call me stupid but if your putting a T28 i would assume that you have got your fueling sorted to run Big boost and also with a piper cam in there i was only trying to surgest to make it more resposive
    now when i buy or fit a new turbo i dont wack it up to 24PSI i take my time making sure everything else is in order......15 PSI then 20 so on and so forth....
    i know you dont have to "run in" turbos but i would rather find a prob at 15psi than 24psi
    also the tdc adv by 4.4 degrees and the only thing you have to make sure is
    A Fueling is ok
    B high octane fuel is used
    now i again assume most ppl do or will run high octane fuel with a T28 set up and piper cam
    so if my assumptions have given anyone the wrong information i do apologies.....
    https://www.rtoc.org/boards/showthread.php?t=4805
    Non-member SCHWARTZ's Avatar
    Wallington south london
    when i got my car it had a 150main and running standard boost and even the t2 was a bit laggy
    Non-member gtmatt's Avatar
    manchester,sale
    t28 will always be laggy its the nature of that type of turbo
    A Fueling is ok
    You dont have to run big boost though do you, the t28 will make more power at the same boost level as a t25.
    I didnt just go and ''whack it up to 24psi'' my previous setup was set up to provide more than enough fuel for 24psi, and I didn't go bang....
    Dec 2009
    west midlands
    The man with the red dimma 5 put your hand bag on the floor.
    Non-member J8TRO's Avatar
    Stourbridge
    I run a T28, mine is well on boost by 3.5k. If your not feeling it in first gear something is wrong.............
    Non-member Spooky's Avatar
    Sep 2001
    SW PMT HQ
    I've run a few variations of "t28" turbos and the one thing that I've noticed is that you will struggle to find good boost in 1st, going into 2nd.
    You do have to learn the characteristics of the turbo/engine spec for the maximum grin factor
    I wouldn't worry. If you are, look at investing in another turbo or speak to Adam L for spec advice
    Non-member Adam 005's Avatar
    Dorset
    i run a t28 rb with a .64 turbine housing i get full boost around 4000k and rev to 7000rpm and some time more.
    Classifieds Moderator
    Mar 2004
    unless your doing a full throttle launch i wouldn't be looking for it, id much rather a rolling start..
    i have spookys old lagtronic developments turbo fitted with extra lag and to say its got some lags
    once 1sts out the way and it come in the higher end of second gear
    Sep 2009
    NW London
    Quote Originally Posted by Biggs View Post
    thanks mate,, the red one was my brothers.. parked in my neighbours drive cos of the parking restrictions
    where abouts u from?? how come you were u on my road?
    Sep 2001
    SW PMT HQ
    shes a biggun
    Dec 2004
    Aylesbury
    shes a biggun
    I'm sure mines bigger than yours though!
    Dec 2009
    west midlands
    How about the turbo.
