Results 1 to 22 of 22
    Non-member SCHWARTZ's Avatar
    Wallington south london
    rad fan help
    trying to wire the rad fan back up but cant find the relay where dose it usually hide?
    Re: rad fan help
    Prob hanging around under the alternator matey, normally attaches to the plastic cowling that sits in front of the alternator
    Non-member TrixNFlix's Avatar
    Preston
    Re: rad fan help
    its attached to the back of the radiator cowling, that piece that locates in front of the alternator.
    Re: rad fan help
    i have no rad cowling il go have a look i know theres one under my drivers side light but thought that was for fogs etc and got one where the old aei unit sat but dont know what that one does. cheers guys
    Re: rad fan help
    cant see it and dont remember taking it out if anything i would have just un pluged from it. Is there another way of wiring it up piggybacking off of another relay etc...
    Re: rad fan help
    is it poss to take power from the alternator to the fan and have the earth going through the stat? would that work or just blow up
    Non-member rat1's Avatar
    Feb 2009
    The dog house
    Re: rad fan help
    the rad fan relay on my one is green i think think this is nominal and it near the alternator. follow the wires from the fan.it needs its own relay
    Re: rad fan help
    Gary if you want you can make a seperate wireing system just for the rad fan and switch and run it all from the alternator matey. I know this can be done as I have this on mine,
    https://www.rtoc.org/boards/showthrea...radiator+relay
    Re: rad fan help
    Quote Originally Posted by rat1 View Post
    Rad fan relay is black and looks identical and is identical to all the other relays under the bonnet
    The one you had next to the AEI gary is the relay for the AEI itself, willbe redundant for you now matey
    Re: rad fan help
    cheers matey thats kinda what i was thinking but a cruder version Can i take that relay off and use that for my rad fan then james? or would it mess something else up?
    Re: rad fan help
    also this is just being a div but on the diagram relay it has 86, 87, 30, 85, but on my relay it has 1,2,3,4,5 dose anyone what numbers correspond to what or how do i find out?
    Re: rad fan help
    Should be ok to use all depends how you have wired up the Volvo bits, if you have used exisiting AEI connections that go through the relay you will prob have to leave it in place but if you haven't remove it and use that relay
    Re: rad fan help
    na volvo loom staying seperate from old loom taking it off of the ignition barrel and alternator. anyone got and ideas on the relay
    Preston
    Re: rad fan help
    id say 1= 85
    2=86
    3= 30
    4= 87a
    5= 87
    i think
    Re: rad fan help
    id say 1= 85
    2=86
    3= 30
    4= 87a
    5= 87
    i think
    Prob best to look at the pins and look a the image attached it may help you work it out
    Re: rad fan help
    cheers guys i should be able to sort it from that.
    Non-member tiff_lee's Avatar
    Glasgow/Lincs
    Re: rad fan help
    I'd just wire it up via a standard 4 pin relay using the alternator for supply and ground with the fan switch as the trigger, it leaves very little to go wrong and if it does makes fault finding even easier.
    Re: rad fan help
    ive worked it out as
    1-86
    2-85
    3-30
    5-87 dose this seem right?
    Re: rad fan help
    wired it up as in the diagram may try and get a 4pin relay but at min 5pin will do. will have to wait and see if it works. cheers for the help chaps
    Glasgow/Lincs
    Re: rad fan help
    You don't specifically need a 4 pin, if you have a 5 pin you just leave out pin 87a (the middle one)
    Re: rad fan help
    yer thats what i have done was just in case i hadnt worked out the pins correctly
    Dartford
    Re: rad fan help
    Just short out the fan switch if you want to test it...
