Page 2 of 4 FirstFirst 1234 LastLast
Results 51 to 100 of 165
  1. #51
    Non-member Fordy's Avatar
    Aug 2010
    Cambridgeshire
    Re: My White 5 gt turbo project
    Its now officially mot'd! :mrgreen:
    Only advisorys was
    oil leak from sump (think the flywheel side half moon seal moved when the sump went up)
    Antiroll bar bushes cracking
    Slight play in steering rack internals
    Had to slow the idle speed down and the co was 2.10 not to bad considering it was set by ear
    now to fix an overboost issue and oil leak
  2. #52
    Jul 2003
    Nice one
  3. #53
    Aug 2010
    Cambridgeshire
    Got some better pictures of the pipes and the ktec carb top
    Can someone please help me sort these out as i'm boosting far too high 20psi easily and dont wanna pop another engine
    carb base to t-peice too bov and aei unit
    Ktec carb top ports
    How its plumbed atm
    Should this pipe go on this port?
    Should this pipe fit to this port?
    Also its made official, only 2 weeks till respray so lots of prep work to do
  4. #54
    Your last pic that pipe with the one way valve and metal pipe going to turbo elbow should go to the other port on the carb and it goes to the back port on the actuator
  5. #55
    Aug 2010
    Cambridgeshire
    Are you sure James? I fitted them like it before copied from my cousins and it over boosted
  6. #56
    Quote Originally Posted by Fordy View Post
    I am 100% sure Adam, been a while since I have seen or worked on an OE stlye setup
    https://www.rtoc.org/boards/album.php...pictureid=3503
    You could always do the boost cup mod and let the rear port on the actuator go to air like we did on JRP's 5
    https://www.rtoc.org/boards/album.php...ictureid=15129
  7. #57
    Aug 2010
    Cambridgeshire
    I got a feeling the restricted port on the ktec is in the wrong place
  8. #58
    Run the cup mod matey
    Loop the 2 outputs on the ktec carb top to each other,
    bolt in rear of turbo elbow,
    pipe from carb base to front port on actuator,
    2nd port on actuator just goes to atmosphere,
  9. #59
    Aug 2010
    Cambridgeshire
    new oil return pipe is here so i can remove someones bodge of copper pipe, just need to source some hoses for it as everywhere seems to want £25 each for them
    And since its raining and tommy doesnt like the rain
    So he is having his sump pan removed and the half moon seals changed in hope to fix the oil leak,
    if it dont fix it then it seems its a rear main seal gone.... BAD times
    Does anyone know if the top and bottom oil return hoses are the same or different? and what size bore pipe?
  10. #60
    Aug 2010
    Cambridgeshire
    Small update
    Only 5 days till its respray time :mrgreen:
    The tables have turned now and my bro is telling me what to do now, since he is the bodyshop boy
    Doing prep work at week nights and all this weekend
    Not much left to prep at all but removing as much trims etc as possible to save time stripping and masking up
    Garage cleared
    The Bro brought home some proper high build primer and tools etc
    Car masked up
    The Bro in action painting the front bumper
    Guide coat on bumpers
    Front bumper ready for paint
    Whole passenger side is ready for paint aswell but no pictures of it.
    Only the door shuts left to scotch off
    8)
  11. #61
    burton on trent
    looking really good fella, not much fun flatting guide coat is it..
    All hail high build!
  12. #62
    Non-member g10far's Avatar
    Berkshire
    Great project thats really coming together, hats off to you for the commitment! Keep it up, look forward to seeing the end result!
  13. #63
    Aug 2010
    Cambridgeshire
    well the car is pretty much fully prepped and whilst my bro was finishing off the passenger door shut....
    I started to play :mrgreen:
    No grill at the moment as my old one is beyond repair so a new one is coming when i can afford it
    Standard bonnet
    Bad boy louvered bonnet unknown origin?
    Come to the conclusion that it wont be used ever as,
    1. the bonnet needs that much repair work i have no energy left to do it
    2. it doesn't suit the car imo
    3. my brother hates it and thus wont paint it for me :lol:
  14. #64
    Classifieds Moderator
    Mar 2004
    can you return the vented bonnet to OE by cutting off the eyebrows? could be worth doing in your spare time once the cars done
    looking good tho
  15. #65
    Aug 2010
    Cambridgeshire
    sadly not as its a properly made louvered bonnet full of metal no fibreglass anywhere
    next idea is carbon bonnet
  16. #66
    Aug 2010
    Cambridgeshire
    He's in the spray booth and omg its a big booth indeed
    Seems like such a luxury to have so much room
    Anyways pictures as always
    One tall booth
    Little shot of the stuff they have in for painting etc
    They have a few redbull f1 racing units and even a few FIA trucks being worked on and a couple in the other booths
  17. #67
    Non-member philg's Avatar
    Aug 2009
    Newcastle
    looking good
  18. #68
    Aug 2010
    Cambridgeshire
    So after a lovely 530 wake up after my brother had attacked me with a torch in my eyes and slapping my head to wake me
    We finished the masking then gave it a final look over and quick prep of some areas
    Primered
    Final coat - renault glacier white - also the same as ford cosworth white
    its not been flatted and polished yet so still a bit "factory finish" here and there but that'll all be done in a few weeks at home
    8 o'clock start tomorrow morning reftting everything ready for the drive home where all the trims will get fitted on and cleaned etc
  19. #69
    Non-member R5TURBORON's Avatar
    Nov 2008
    nottingham
    amazing work mate i need mine doing when i get a new front bumper got to find somewhere decent
  20. #70
    Aug 2010
    Cambridgeshire
    We did want to stonechip the bottom lip of the front bumper so it didn't get any stonechip damage.
    But we completely forgot about it as we was amazed how nicely the paint went on. Will need a bonnet and bumper bra made up me thinks now to protect it
  21. #71
    If you haven't got tits then don't wear a bra
    Looking absolutely great btw
  22. #72
    Non-member Jonny5's Avatar
    Sleaford
    Simply Stunning
  23. #73
    burton on trent
    looks really good that does dude, well done for doign most the work yourself, its a real buzz, but best of all its not the end of the world if you knock it as you know exactly what to do to repair
  24. #74
    Aug 2010
    Cambridgeshire
    He's back home after a little trip round to see my cousins and they love it
    Gave them a kick up the arse to get their tungsten one back on the road
    Still a few trims to fit etc but the most has been done and we can have a rest for a week
    BUT its not all good news! Like a true renault 5 it has a new problem.......
    Its clutch has decided that with the newly rebuilt engine and all the new power plus a spirited drive home, the clutch didn't like it and started to slip on full throttle after 3k
    So new clutch time yay....
  25. #75
    Aug 2004
    Nothing better than a mint white 5, looks very shiny
  26. #76
    Non-member raj's Avatar
    Feb 2001
    Rohtang pass
    Quote Originally Posted by Penfold aka The Dealer View Post
    i agree, im loving this 5, some good time and effort been put into this
  27. #77
    Aug 2009
    Newcastle
    fresh fresh fresh, ah it take me back.
    Looks great
  28. #78
    Non-member rs250nut's Avatar
    Nice booth
  29. #79
    Non-member TNT ANDY's Avatar
    Simply gob smackingly beautiful.
    Good work.
  30. #80
    Non-member Wallace's Avatar
    herts
    Looks absolutley stunning
  31. #81
    Aug 2010
    Cambridgeshire
    Gearbox is out with the engine in situ.
    Its tight but not hard as i've not sworn at it yet this morning.
    Big thanks to mike at gt turbo spares for the uprated clutch 8)
    Bonnet and bumper off. Covers on and an no zips on trousers rule set down we like the paint work unscratched
    Gearbox removal
    Found my persistant oil leak - rear main oil seal wrong way round :roll:
    Found a possibly cause to my funny vibration at 50mph
    Yup thats a hole in the diff and some pretty deep grooves,
    The shaft bearings looks fine and theres no pieces floating in the other half of the diff...
    On the hunt for a new one might try scrappys tomorrow
    If no luck then i'll put it all back in and buy one from renault and do it in situ with the shaft out
    So the list of things found wrong:
    No roll pin in o/s driveshaft
    Rear main oil seal fitted wrong way round causing my oil leak thats gone over the flywheel and clutch
    Gearbox n/s diff section has a hole in it and deep grooves
    The bro did some cleaning while i removed the gearbox
    Now to de-grease and repaint the box silver casing and black end cover like it should be
  32. #82
    Aug 2010
    Cambridgeshire
    Right way round now :roll:
    Went on the hunt for a new diff gear and went to the local volvo scrappy as it was the only one open today :roll:
    there is a few good 440 turbos in here hiding
    Rolled over a 440 1.8 no turbo and got to work
    Oh yeah no more holes
    found this awesome idea on the same gearbox, Return spring on the gearbox rather than the linkage. so far it seems to work fine
    Gearbox in
    Got a mega headache so come in for a rest and tablets so this is as far as i got yesterday afternoon
  33. #83
    Aug 2010
    Cambridgeshire
    finished off today
    Bailey dump valve removed after finding it was leaking when we was cleaning it
    Then we found out a knocking noise from the drivers front wheel when pulling it in and out at the top
    Found both top mount bolts loose enough to move
    Tried undoing one and it snapped
    So off with the drivers strut which turns out to be koni adjustables then ground off the captive nut and rewelded a new nut to the bracket
    Refitted it and took out the passenger sides and copper greased them up for good measure and jobs a gooden
    Then we decided to put the strut brace on since "fingers crossed/touch wood" all the engine work is done
    We then cleaned up the earths on the front of the car and put the bumper and bonnet back on
    Took it for a spin up to tesco and treated the car to a full tank of 99 octane, then popped round to halfords for a new clio rear wiper blade and some satin black so we can paint the wiper arms next
    Feels good being able to give it full throttle in any gear without having to worry of it slipping anymore
    and i love the green box volvo clutch ok its a bit grabby but its not really that hard on the pedal, i've driven worse clutchs in the past
  34. #84
    Non-member GTphil's Avatar
    Oh how i wish i could get my five painted!!
    Nice work!
  35. #85
    Aug 2009
    Oxfordshire
    Some nice work there fella on the prep and paint. That paint booth is huge! Seeing yours painted makes me want to finish mine asap
  36. #86
    Aug 2010
    Cambridgeshire
    Small update
    Radio wiring has been fixed after some time with continuity tests and finding lives and earths
    Radio is a classic kenwood cassette headunit given for free by a friend as i Didn't want anything fancy to stand out like a swore thumb
    Also my new grill from renault for a bargain price
    Brother will be painting the grill sometime this week for me.
    In the meantime he has a Mini A series engine block i need to start building into a turbo block
  37. #87
    Aug 2010
    Cambridgeshire
    Time to update
    Grill painted and fitted on, it finally has a sexy looking face rather than a black hole
    Then plugged the aem uego on
    Majorly lean as boost hits
    So ordered a new fpr from renault
    Which didn't fix it.. DOH! oh well its another shiney part fitted
    So onto the lean issue
    Tried a few things like accel pump adjustment - no difference
    Whilst doing a power run down the road the accelerator cable fell out the linkage - fixed on roadside
    Found a nice major oil leak from the rocker going onto the exhaust making a bit of smoke
    So after that i got moody...got home and put the car in the garage (Its favorite place)
    Took off the strut brace, rocker cover and carb
    Fixed the rocker cover leak
    And proceeded to strip down the carb + a good spare on in the garage that hasnt been used for a while
    And found this little bugger was semi blocked
    So swapped it out for a good spare, and reset the accel pump with a 5mm drill bit
    Then i thought lets go for a bar of boost, so swapped the ac jet for a 1mm and drilled the 2nd stage to a 1.2mm and fitted everything back together.
    Just need to get a new fuel filter and bleed the coolant and see what we have tomorrow on the aem... fingers crossed at 10psi it overfuels enough for me to up the boost a little to 14 psi
  38. #88
    Committee Member
    North West Regional Area Rep
    BluntyR5GTT's Avatar
    Nov 2009
    Stoke-on-Trent
    looking good mate
    how much was your fpr if you dont mind me asking? hey id imagine you would be able run a tad more than 14psi if you set your carb up with 1.2mm 2nd stage and 1mm a/c
  39. #89
    Aug 2010
    Cambridgeshire
    its was £44.88inc vat from renault but i get alot of discount as i know the parts bloke very well
  40. #90
    Committee Member
    Nov 2009
    Stoke-on-Trent
    thats not bad at all, as i wanna replace mibe just toying with idea of standard or adjustable fpr
  41. #91
    Berkshire
    Great project, it's great to see what you can achieve with lots of hard work.
    The car looks amazing keep up the good work!!
  42. #92
    Non-member 5 turbo's Avatar
    Mar 2011
    Give yourself an your painter a big pat on the back...Lovely Job on her
  43. #93
    Aug 2010
    Cambridgeshire
    Still dont know if its fixed the lean issue but i know it is clean and polished
    few of the bros mini aswell
  44. #94
    burton on trent
    looking great dude, should be proud.. be nice to have a chat with ya at national day when you come grab these lights.
  45. #95
    Non-member benj88's Avatar
    Mar 2010
    lovely mate
  46. #96
    Oct 2003
    looks stunning, fresh, white with the bump strips off make it look awesome. only thing that id change if it was me is the white ariel
  47. #97
    Oct 2004
    Somerset
    , couldnt agree with adey more....apart from a fresh white phase 2 like that surely deserves orange/standard indicators etc and decals...., keep up the good work fordy...what a transformation!!!!!!!
  48. #98
    Member Lomo's Avatar
    Wirral
    Car looks superb!
  49. #99
    Aug 2010
    Cambridgeshire
    i'm not to sure on the decals, it was always my plan untill the bumpers got smoothed now i'm not sure if it will suit it
    orange lights hmmmm might have to swap with someone at national day see what it looks like, since i need a new clear one anyway as the locating lug is broken off so it sits wonky
    if someone could photoshop the decals on so i could get an idea of how it looks that would be great
  50. #100
    Non-member xenon's Avatar
    08 ardenne
    superbe
