Results 1 to 19 of 19
    Non-member reco's Avatar
    Aug 2010
    Glasgow
    my clio gtt
    as you all may know bass j secured a 5 from here it was chris5sco's i was in plymouth for a month working but when home we got to hunting for rot unfortunately it was a tad rusty :O
    all pics are bobs phone
    we sourced me a clio 1.2 RL without a sunroof which passed its mot a week last monday ago with a wheel bearing and needing the rear brakes fixed i drove it for 2 days soo slow back to the fun
    got both cars down to the garage on friday got the 5 running and left it till saturday
    morning took the 5 engine out and started on the clio. now the pics
    clio before
    yip this is me andthe messy garage lol
    engine ousted from the 5 was quite quick
    now to start on the clio
    armed with a drill and preped the clio for the 5 engine using knowledge gained from mistakes made while getting bass js betty up and running i sorted the fuel pressure reg now sits snug and nice under the brake servo bolted to the chassis leg
    engine in
    not to bad for a weekends work id say
    ps we used the 5 exauhst and drive shafts <they need changed there just too short but they work to drive the car up the road
    i just need to sort the brakes 1.2 ohhh noooo lol
    wiring needs a few tweeks i couldnt get the 5 dash oil light to work and the oil level sender the ph3 clio has a different loom to betty lol
    i will be getting some gauges for oil water ect
    and fixing the battery which at present is situated loosely on the passenger foot well
    one thing but i dont know about is the speck of the engine there was an adjustable (lockable) boost controller i took it off so if anyone knows any info about the engine please feel free to share your knowledge
    cheers for reading i will update this when i make progress
    Glasgow
    Re: my sleeper clio gtt
    I drove this ..such a sleeper ..needs the gtt brake setup we both think and some boost
    I actually enjoyed building this clio more than i enjoyed(hated) ..building mine
    Non-member BriC's Avatar
    Dec 2005
    Only just seen this... nice sleeper
    Aug 2010
    Glasgow
    forgot about this thread
    pics from yesterday
    full gtt exhaust fits snug on the clio
    before i moved the air filter and water bottle i will get more pics after snow goes
    shiney new waterpump (forgot anti freeze )
    my other clio RSi hiding under the snow
    Non-member benj88's Avatar
    Mar 2010
    Sleepers are ideal
    Was the 5 bad? Looks like it's in ok condition or was it quite rotten?
    Glasgow
    aye the 5 was rotten lol ..here's how bad the floor was on one side -
    the sills had massive holes in them aswell ..wouldve cost us too much to weld it all up
    Mar 2010
    Yeh ah bet it would! Lol
    Nov 2010
    Burntwood Staffs
    i want yellow boost hoses
    nice job boys..
    Glasgow
    Well last weekend we fitted my old turbo technics stage 1 t2 turbo to this engine. Its doing a weird thing on boost ..its chirping! ..spoke to markey mark on the fone he said the boost was too high ..so we turned it down..it still did it. Then me knowing the actuators set to 10psi ..we just straight piped the actuator to the carb and it still did the chirping ...has anybody got any ideas?
    Quote Originally Posted by Bass J View Post
    Bobby what do you mean by chirping?
    Glasgow
    as if its waste gate chatter but not the full chatter..if that makes sense?
    Has it only done it with this turbo you have just put on?? could just be the fact different type of turbo different compressor stall sound.
    Glasgow
    aye only since he fitted it.. its my old unit ...it ran fine on my engine. which we thought was weird that it did it on his. His old turbo didnt do this on his engine either.
    Aug 2010
    Glasgow
    fitted the standard turbo and did a few other things this weekend
    well today been a busy bunny
    fitted a different driveshaft and lowered the rear a bit CLIVE IS HOME
    front lows 60mm
    family mobile daily runner
    and now home sitting with pride
    i must admit i did turn the boost up a tad on the drive home
    all thats left is sort out the batery box and new callipers
    and a good clean
    Glasgow
    Shoulda gave me a phone reco lol ..i was tinkering with my clio today ..got it running proper also
    It looks good with them wheels on it what driveshaft did you use in the end?
    good to see its home man
    Aug 2010
    Glasgow
    took the one off the Rsi split pin was a c**t to get off the 5 box lol
    Glasgow
    Lol at least you got it done
    Roll on FCS
    Aug 2010
    Glasgow
    after its longest run yet from billing to N/D then to fcs on the sunday
    it was good to meet a few members but in the run back to billing from fcs on Sunday the top water pump hose let go lol at the gates of billing
    refitted hose and i thought i had got away with it but im leaking oil now
    noticed this when the kids started saying the cars on fire lol
    oils dropping onto the exhaust manifold
    so will be stripping it down over the weekend to find the problem
    Glasgow
    Quote Originally Posted by reco View Post
    ah feck reco! ..i think we should ditch the c1j's after the luck weve had or should i say ...me p.s give me a shout if u want ...if i aint doing anything ill pop over
