Cam is retarded for more top end power
I think this is a pump issue myself, as i can rev it to 7.5k in 4th & 5th gears without emptying the float/leaning off. Ive got all the bits to supply more fuel to the bowl but as it has never leaned off in high gears ive never seen a reason to mess about with it too much.
I will whack a gauge on & see whats happening with the fuel pressure, its hard to get it to replicate on the road though, as wheels are normally spinning like feck in 1/2/3 gears on road tyres. No load no problem really
It seems to be worst when fuel is under half a tank thats what made me think about a swirl pot.
Surely if i fit a decent pump with a better flow rate, the regulator will return the fuel that isnt needed to the tank & as the reg sets the pressure it shouldnt alter at the needle? 044 is prob overkill i admit id probably pick a cheaper alternative.
