noisey starter motor!!!!
hi again, i now have a problem with my starter motor its very noisy when cranking its the second one i ve tried, i have the dowel in the second hole down and it all seems to sitting flush, i can see from underneath that the pinion gear is not fully engaging to the flywheel?? the flywheel teeth are very slighty marked but not too bad. any ideas fellas???
Re: noisey starter motor!!!!
