Results 1 to 16 of 16
    Non-member tubby5's Avatar
    york
    smokeing like a ****
    hi guys got a small prob(which will prob turn out to be a big prob)ive just replaced a liner as the old one had cracked and the engine hydralocked blew loads of steam out the exhaust,but after putting everything back together today and starting it up.the engine sounds a bit rough(lumpy) on idle.and also after 3-4 minutes started smokeing out the exhaust,not so much on idle but if you blip the throttle it chucks out a fair bitmy old man reckons its excess water in the exhaust but im not to sure as the idle is rough also the afr,s have changed its now reading high 11,s low 12,s
    if the tappets were to tight would this cause any of the above problems????
    thanks
    Non-member raj's Avatar
    Feb 2001
    Rohtang pass
    Re: smokeing like a ****
    my first port of call would be to recheck/readjust the tappets and go from there
    Oil going past the piston rings, or valve guides, or turbo seals.
    Is it oil smoke or water smoke?
    york
    yeah thats tommorows plan now cheers mate,so would you think it could cause the above probs???
    to be honest ive never done a liner/headgasket before until this wkend,and if its something i have done i will be well gutted(eg liner not sealed or something)prob not as ive had some good advice
    york
    white/greyish smoke ???
    felixstowe
    does it smoke from cold? or is it after the oils got up to temp?
    york
    nah it only started when it was warming up after about 3-4 minutes
    Non-member BlueFish5Gt's Avatar
    Greece
    Something might have gone wrong with the new head gasket or perhaps you've got a crack on your cylinder head .I'm not as experienced as others in here but I think that might be it.
    york
    the head was checked when it was skimmed,im hopeing its not the headgasket,prob best buy my self a compression test gauge and cross my thingers
    Dec 2004
    Aylesbury
    If you cracked a liner you've probably shot aload of water through the turbo and into the exhaust so that couold be the smoke/steam.
    For it running rough does it sound like its missing abit, i've found that when i've hydrolic the piston before i have bent the con-rod. Did you check the rods before putting it back together.
    york
    bent a rod i never checked i just presummed everything else would be ok
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Quote Originally Posted by tubby5 View Post
    as I said in the pm mate, that's steam, it'll take a few motorway miles to burn it off, don't stress.
    york
    always expecting the worse thats me
    Dec 2004
    Aylesbury
    I've had it before mate when i cracked a liner
    Oct 2007
    costa del walney Island NW
    hav eyou done an oil change since changing a liner ? if not you will have water in the oil still.
    york
    sortedi reset the tappets and it idles smooth as,and the smoking has stopped,just have an oil leak from the sump but im happy
