Results 1 to 13 of 13
    Jul 2009
    Clevedon, Somerset
    Rear brake proportioning valve
    My 11T failed its MOT on a leaking proportioning valve.
    So I need a new one.
    The question is:
    Is the 11T unit shared with others such as 5GTT?
    Where can I get a new one, other than Renault?
    Ta chaps
    Re: Rear brake proportioning valve
    You can't buy them new anywhere unfortunately. The R5GTT is not the same but it can be modified to fit. That said, even the R5 units aren't easy to come by these days either.....
    Jul 2009
    Clevedon, Somerset
    OK, thanks.
    I'm just looking at a 19 16V unit (which having now found some pictures I think is essentially the same as the 5GTT one) and trying to work out if I could make it work.
    Problem I can see is that the two types seem to work in opposite directions if you see what I mean
    Do you know who has done the mod before? Any photos?
    Jan 2010
    Hungary
    Quote Originally Posted by Neal 11T View Post
    The question is:
    Ta chaps
    There are two type.
    to 86/09 : 77 01 349 306
    from 86/09 : 77 00 674 642
    All type of R11 has those types
    Non-member dave j gtt's Avatar
    Oct 2007
    costa del walney Island NW
    clean it all up. nip all bolts up and an paint it.... job done till next year. or at least try that
    Jul 2009
    Clevedon, Somerset
    Trouble is, the tester got hit in the eye by a jet of brake fluid from it.
    So when I say it's 'leaking' I mean it really is leaking and no amount of paint is going to disguise that!
    What I will do though is remove it, strip it down and see if I can recover it with new O rings etc.
    Watch this space.
    Non-member paul-11turbo's Avatar
    merseyside
    Did you eventually get to strip it down and fix it???
    Is the part where the spring is supposed to move in and out?
    Mine has failed mot on rear brakes not being good enough and all it can be is this bloody valve thing.
    Non-member Schakal's Avatar
    Barry
    Quote Originally Posted by paul-11turbo View Post
    you dont need to strip them , mine failed a few mots for the same
    reason on the 19 16v .
    a good half an hours work under the axle with a can of wd40 and some
    basic tools fixed it everytime
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    Quote Originally Posted by Schakal View Post
    problem is tho shak attack..... the bugger is leakin...
    hey neal when you take it apart fire up your findings on here if you
    can,be interesting to see if there fixable....
    also get urself to the next pub meet down road from clevedon..
    J
    bracknell
    neal .. a new fuel filter would also be a good idea
    merseyside
    I managed to get the piston thing that the spring pushes against moving when the brakes are pressed but the mot man tested them again and it has made no difference
    Barry
    Quote Originally Posted by J$£5GTT View Post
    J
    i was refering to paul`s one matey
    THE BAT CAVE
    ohh.......
