Results 1 to 21 of 21
    Non-member gtmatt's Avatar
    manchester,sale
    172 issues
    Well I've posted on Clio sport with no advice.
    Right team my Clio went in limp mode last night started revving high on idle 2k-3k called aa out did a diagnostic test fault came up accel pedal sensor ,started this morning came out of limp mode and just holds revs now high ??
    Could this be pedal ? Throttle body ?? Or coil pack ?
    Also what code reader do I buy of eBay to work on a 172 phase 2
    Thanks team matt
    Jul 2003
    Re: 172 issues
    You'll not get a lot of response off Cliosport unless you post something about Cleaning or tuners!
    Could it be something to do with the Idle Control Valve which is on the back of the inlet plenum? Millie's plays up sometimes & I just give it a clean with some spray cleaner & it sorts itsef out.
    Re: 172 issues
    It's a phase 2 so doesn't have the idle control valve as it will have fly by wire TB. My first thought was idle control valve then I read the phase 2 part, I would prob say take the Flyby wireTB off and give it a clean up.
    With ref to code reader you need an OBD-II reader to plug in and then type the code you get into the google box on the internet and it will tell you what it is (that is if you loose the code book like me )
    manchester,sale
    Re: 172 issues
    Thanks james and steve ,will get a code reader ,I have bought a accel pedal got to fit that ,will check throttle body also ! Could it be coil pack ??
    Thanks again matt
    Re: 172 issues
    Thanks again matt
    Faulty coilpack would prob cause missfire's I doubt it will cause high revs, I have an OBD-II reader if you fancy borrowing it? it's simple literally plug it in and do the scan's it will give you codes and then as said just type them into google and it will tell you what they are if any found that is.
    If the AA done the test the OBD-II reader will prob give the same error code aswell, might be worth clenaing the other bits up as said above and changing the accel pedal sensor as the phase 2 TB is electronically controlled and not cable like a phase 1.
    manchester,sale
    Re: 172 issues
    Thanks for the offer James ,going to buy ,cheers for the advice will let u all know my findings thanks matt
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Re: 172 issues
    James, I don't think you've lost it....
    In the process of moving house I found a book full of codes... I think it may well be your scanner book!
    PM me ur address and I'll bang it in the post, sorry dude, musn't of given you it back!
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Re: 172 issues
    Matt, Also check the breather that goes from the top of the rocker cover to the carbon canister or the seal around the bottom of the plenum havent split and are causing an air leak.
    Re: 172 issues
    Cheers Nial, pm your way
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    Re: 172 issues
    Sounds like an air leak, as ya man Ashy said. Might also be worth checking the coolant sensor hasn't gone up the spout, and that the pedal/throttle pot' isn't 'noisy'.
    Have you tried disconnecting the battery, leaving it a good while to allow the ecu to 'reset', then seeing what happens after reconnecting the battery?
    manchester,sale
    Re: 172 issues
    done a master reset on ecu ,to drop out the caps in the system.
    I will check for air leaks but obd said accel pedal ?? which is a 4 track potentionmoter ,i have looked at this no issues.
    took of the throttle body cleaned and re fitted still the same , revs holding at 2k-3k
    thanks you all for your help matt
    May 1996
    Pie & mash shop
    Re: 172 issues
    What resistance you getting on that pedal pot'? A sniff on Google should point to what the idle/rest & w.o.t position resistances are.
    May 1996
    Pie & mash shop
    Re: 172 issues
    Defo check the coolant sensor as well.
    Oxfordshire
    Re: 172 issues
    this is for Steve as it's PH1 related...
    I removed mine and filed off the rivets to get the TB apart, there was a lot of oily build up around the seal, I could give it a much better clean in bits. Used 2 M4(?) bolts to hold it all together. I don't think you can clean it properly with spray.
    OP - try blocking the TB, if the engine keeps running you have an air leak in the plenum. Also, unless you monitor the pot with an oscilloscope you won't see the damage unless it's completely fooked, which clearly it isn't as the car runs.
    Non-member Gttnutter's Avatar
    Oct 2005
    Amersham
    Re: 172 issues
    Just a thought but you can check for faults on the dash (like a self diagnostic)
    with ignition off press and hold the right indicater button on the end, after a few seconds switch ignition on then release the indicater button
    It will go through a cycle and all the dial needles will go mental and all the dashpod symbals will light up
    If you then press i think the right button on the trip computer you can go through to fault codes ie: t----h, something like that should appear, That one is an injecter fault quite common i beleive
    Write down what you see and you can relate with the one like google
    To come out of it just turn ignition off,
    You can also start the car in this mode, but not ideal as you wont know what speed your going!
    Hope thats some help
    Oct 2005
    Amersham
    Re: 172 issues
    I think its quite common for the inlet plenium egg shaped seal to leak
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    Re: 172 issues
    accelerator problems are common, u can try a used known good one as there not coded. You can check idle and wot but its not that simple usually. u have to watch the graph readings of the 4sensors and watch for any discrepencies.
    Non-member GTphil's Avatar
    Re: 172 issues
    Just get your gtt on the road, much more reliable!
    Non-member J8TRO's Avatar
    Stourbridge
    Re: 172 issues
    Shocker
    No dig at you but CS is pants, thought i'd get some good advise off there too and got nothing
    RTOC FTW
    Jan 2010
    durham
    Re: 172 issues
    I have a 172 FBwire thottle bodie, ill send it down if it helps pay if not return?
    AG
    Sep 2005
    Parkgate Cheshire
    Re: 172 issues
    The signal from the pedal sensors and throttle sensors are usually opposites. eg 2 on the pedal when at wot will be 4.5v and 0.5v then as you return to idle the pedal would be 0.5v and 4.5v
    Ill try make that clearer, one of the 2 on the pedal will start at 0.5v then rise gradually and evenly as you reach wot at 4.5v the other sensor should do the opposite start at 4.5v then gradually decrease to 0.5v pretty sure thats the renault way. some manufacturers are half eg one is at 4.4v wot and the other is 2.2vwot
