Results 1 to 5 of 5
    Jul 2009
    Folkestone - Kent
    xp problem
    Can someone give me a hand please as im pulling my hair out
    about 3 years ago my wondows xo computer decided to die so i bout a laptop.
    yesterday i decided to try and ment it,
    the problem i have is its on a automatic reboot loop, no comands work on f8, no blue screen when i do select anything its bleeps and sayd no input signal and reboots
    if i dont push f8 i get 2 seconds of loading ( writing on black screen) and then restarts saying the input signal message then bleeps then restarts
    its wont disable the automatic reboot failiure optoin or anying.. i have no options
    i cant find a xp disk either to make a ultimate boot cd due to my nex xp pc is a not book with no cd drive so it doesnt come with and xp cd
    Non-member Slim's Avatar
    Sep 2009
    NW London
    Re: xp problem
    chuck it mate,,, more hassle than its worth fixing...
    Sep 2009
    NW London
    Re: xp problem
    sorry,, i thought i read you dont have a cd rom. IF you have,, js download an OEM version of windows XP, as long as you have a valid legal product key,, you should be ok.. I think
    Non-member tiff_lee's Avatar
    Glasgow/Lincs
    Re: xp problem
    So you have been without this pc/xp install for 3 years? would it be safe to assume then that there was nothing on it worth saving since it has been left for so long?
    Without a windows cd there is not alot you can do.
    Non-member MFaulks's Avatar
    Dec 2008
    London UK
    Re: xp problem
    Can you get into bios? You would need to google which key or combination of keys you need to press for your machine and then get into bios. Most likely it has lost all setup, and the back-up battery is probably dead. If you can get to bios you can check the basic machine setup and change where it looks to boot, and follow what has been suggested and boot from a minimal CD. Good luck.
