Results 1 to 25 of 25
    Non-member gttjames's Avatar
    Cambridge
    recomend some good front pads for road use/spirited drive?
    Dont do track, just use the 5 on nice days and nice weekends with a good thrash. What are the options on front pads availlable guys? Will any big brand oe pads be good enough, ie lucas/trw/pagid/ferrodo/mintex etc
    Re: recomend some good front pads for road use/spirited drive?
    Personally if It's just road use I'd be tempted to stick some standard pads on. Ferodo DS2500 are fantastic for the road or track but quite pricey compared to OE pads.....
    Look-Out Kris M's Avatar
    Apr 2006
    Swindon
    Mintex are good IMO
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    oe ftw!!
    I'd be tempted to stick some Ferodo DS2500 on
    Has tended to be the most popular response in threads like this.
    Remember than about 20% of the stopping comes from the rear brakes so by making the fronts bite earlier and with overall less pedal effort the rears will be working less or a lot less and the overall stopping may actually be not quite as good.
    Cambridge
    Yer iv heard good reviews about 2500's everywhere, but there abit pricey for what il be using them for i reckon.
    Out of the ebay listed ones it looks like this
    ferodo 325 £15
    http://cgi.ebay.co.uk/RENAULT-5-TURB...item41511da46b
    ferodo 845 £15
    http://cgi.ebay.co.uk/RENAULT-SUPER-...item335daff40b
    (whats the difference?)
    pagid
    http://www.eurocarparts.com/ecp/c/Re...fb18c35d2&BKPA
    Jan 2010
    durham
    Just spend the money get soem 2500's there amazing!!! no brake fade ever again, mind you they do work a lot better with a little bit of heat in them
    Member Woznaldo's Avatar
    Canberra, Australia
    Quote Originally Posted by gttjames View Post
    ferodo 325 £15
    ferodo 845 £15
    pagid
    The 325's are for mk1 R5, you need the 845 pad fitment but, neither are DS2500.
    Canberra, Australia
    Non-member r5 rich's Avatar
    Romford, Essex
    i got some ferodo ds 2500 slightly used pads and some ferodo rear pads aswell but slightly lesser model if interested pm me.
    Non-member Kenobi's Avatar
    Jul 2006
    Leicestershire
    Are these ferodo far better than EBC red and yellow stuff?
    Quote Originally Posted by Kenobi View Post
    Yes much better, keep away from the EBC biscuits
    Jul 2006
    Leicestershire
    I sell a lot of EBC stuff. perhaps I should push these instead.
    Cambridge
    ebc has a big name, probably to do with the fact there in the mags and halfords etc, never heard a good review about them.
    Just ordered the ferrodo's for mine (not the ds2500's just the regular ones)
    Non-member Russ B's Avatar
    Aug 1995
    Colchester (Brightlingsea)
    I have Pagid kevlar in mine. They work very well & would recommend them
    I have Ferrodo DS2500 on my Impreza & wouldn't have them again. I've had juddering due to uneven pad deposites. I've read its a fairly common problem due to the pad bonding agent leeching out. I'm going try Mintex 1144 next as I've alway had good results with them in the past.
    Yes I would never use those again. Got swindled by EBC salesman's spiel twice. Both times the pads were very poor and very inconsistent. Apparently they'd had 20 different formulas between the ones I wasted my money on; V1 and V3 or 4, I forget.
    Member clee's Avatar
    Derbyshire
    Anyone used the 1144 on a heavy ish car ? 1100kg ?
    I fancy trying a front set for Mallory .
    Even though I don't like EBC I have greenstuff on the fronts and the black ones @ the rear. But these have been on my car for years as it's only a weekend car I haven't had to replace them yet as loads of meat left but when I do I will be looking into Ds2500, Mintex or the carbon lorraine jobbies.
    Non-member Yellow's Avatar
    Jul 2009
    Portsmouth
    I had ds2500 on my r26, cracking pads but whenever It rained over night or got wet and left for an hour or so, when taking up drive would make a nasty sound as though they had stuck to the discs. Only done this after I swapped from standard Renault pads to the ds2500.
    Cambridge
    Well its disc and pad time for my r26 aswell, was going to go with the ds2500 on that... dunno now though
    Cambridge
    Got the pads through today so il fit them in next couple of days and report back
    Aug 1995
    Quote Originally Posted by clee View Post
    Very good fast road pad Clee, not to sure how they stand up for track use though.
    Jul 2009
    Portsmouth
    When I done mine I only replaced the pads an left the discs not sure if this would make any diff but they deft felt like they had momentarily stuck like you had just done a few laps of a track an stopped and put your hand brake on and the heat had stuck em, but only if it had rained or you'd just washed the the car. Little bit embarrassing on your brand new motor though sounds horrid. Also found plenty of meat on discs but started to look like a vinyl record. I had the car from new and only changed pads, maybe should of done the discs to.
    Cambridge
    Done 150 miles with them now and pedal slowly got better, was feeling good after 80, did a good run with them yesterday and braked hard from 80 ish and pedal was pretty impressive actually and didnt fade - im happy with them
    Quote Originally Posted by Yellow View Post
    Sounds like the discs rusted over a little bit. My standard rears did it for years.
