Results 1 to 6 of 6
    Non-member 1.7r5gtturbo's Avatar
    Jan 2010
    nottsr5s
    fuel injecters
    Hi agen lads had sum problems starting b18ft on sat and found out my injecters were shaged couldn,t get them to open up so I replaced them with sum vauxhall red top ones and it fired up strate awy runs nice could do with a tweek here and there but runs the problem is are the injecters ok for this engine they looked just like the std volvo ones even the clips wot hold them it fit any idears lads thanks
    Non-member sieger's Avatar
    assen city
    Re: fuel injecters
    are there any numbers on them?
    the injectors have to be high impendace
    http://www.injectorcleaning.co.uk/flow.htm
    Jan 2010
    nottsr5s
    Re: fuel injecters
    thanks m8 just wot i needed
    Jan 2010
    nottsr5s
    Re: fuel injecters
    I'm I right saying the std b18ft ones are 200cc and high indapendance at 16.9 homs the red top blue ones are high as well with a flow rate of 240cc but 17.3 homs high indapendance will these be ok
    assen city
    Re: fuel injecters
    should be fine
    Jan 2010
    nottsr5s
    Re: fuel injecters
    cool m8 thanks for the help
