Results 1 to 10 of 10
    Non-member SCHWARTZ's Avatar
    Wallington south london
    head bolt torque
    what torque do you do the head bolt up to on these lumps? and is that wet or dry?
    Non-member Adam 005's Avatar
    Dorset
    Re: head bolt torque
    on which engine buddy.
    b18ft
    wet or dry?
    They should always be torqued up when properly lubed, I thought. Or you get false readings as the friction varies.
    Unless you use an angle gauge and do it by ° and not by torque.
    norwich
    10.9 - 65nm
    12.9 -90nm
    or use the arp f4r stud set which will also fit f7p/f7r and should also fit the b18 head as they seem to share the same length head bolt as f7p/f7r--good for 130nm(for big boooost)
    not looking at silly boost atm but il bear that in mind il do it to 90nm then cheers chaps.
    Non-member dave r5's Avatar
    Aug 2009
    pitsea essex
    [quote=HAndy;160504]10.9 - 65nm
    12.9 -90nm
    or use the arp f4r stud set which will also fit f7p/f7r and should also fit the b18 head as they seem to share the same length head bolt as f7p/f7r--good for 130nm(for big boooost)[/quote
    do the arp's u sujested fit.
    ive bin putting off sending a bolt to arp for ages as i cant afford the 1 of price
    would love to know if they are useable
    Aug 2009
    pitsea essex
    if so can u link to a place where to buy them ta
    norwich
    Quote Originally Posted by dave r5 View Post
    speak to jp racing , he has just got hold of a set from a oversea's tuner who seems to supplie a lot of gear for the f7p /7r engines , i think he also mentioned billet cranks
    but the kit he's got is deffo listed for f4r
    norwich
    [QUOTE=dave r5;160739]
    10.9 - 65nm
    12.9 -90nm
    tried an arp rep myself 7months ago ,total waste of time , had even given him an o.e bolt , no response
