injector problem
taking the engine apart yesterday to give it a nice well deserved clean up (hasnt run in over 2 years) and i couldnt remove the injectors. i de-presurised the system and they were still stuck so i pulled them out 2 came out with a slight struggle but 2 were stuck soild. eventually they came out but they fell apart as they did leaving the cap and the rubber seal in the head. I have got these bits out the head but im wondering if i just put the injectors back together will they just fall apart now that they have come apart?
Trader
Nocturnal Developments
Re: injector problem
i've re fitted them before. i cleaned mine, bit of wet and dry round the outer edge of the caps, fresh seals if perished or slack fit with a bit of fairy or grease to ease them in. just make sur the caps click on and dont pull off easy when fitted.
thats the main thing im thinking of. the seals all look good no perishing but now the caps have come of once will they keem coming off as i dont want that. il give them a clean up put them back together and see how they feel. cheers haz
