Anyone done this, whats best to use paint out of a tin, or rattle cans, any tips and pictures would be great.
phil
phil
vht paint is best from what i have read.
Its had a refurb, so has been cleaned pretty well, i have just went over it again with gunk.
pics would be great mate
No need for expensive VHT, doesn't get hot enough.
If you want it to last get POR-15 from Frosts.
pressure washed and degreased the gearbox then grey primered the gearbox and end casing then using wheel trim silver from halfords painted the gearbox and used gloss black for the end casing
I've used standard paint on cylinder heads before with no problem, no need for VHT there or on the gearbox imo.
I just used some Hammerite Smooth-Rite out of the rattle-can & it still looks ok!
VHT wont react nor does it need prima Just for the record
I used hammerite on mine, the paint outlasted the internals of the gearbox
just regular paint for me, lacqer on top to stop it staining
pressure washer, carb cleaner and normal spray paint.
Finished, thanks for the input guys, good degrease, jet wash, wire brush, metal ready then vht painted.
Looks sweet.
