Results 1 to 5 of 5
    Non-member scott25's Avatar
    Mar 2009
    chesterfield
    Gearbox issues
    Well bin a good week managed to get new crank seal in, engine back in all up and runnin drives and pulls very well, only issue is to reverse i have to hold it in gear and it still kicks it out somtimes, 5th also feels the same its the r5 box on b18 lump anyone any ideas, thanks
    Trader
    Nocturnal Developments
    Haz's Avatar
    Re: Gearbox issues
    could you have bent or moved the linkage? could just be a faulty box, if its a fault from before you stripped it and gettin worse then more than likely
    Mar 2009
    chesterfield
    Re: Gearbox issues
    when it was on c1j it was fine, could av bent somthin without realisin i suppose, i also fitted quick shift and shorter link so may fit standard link to see if it alters anythin, thanks for that anyway
    Mar 2009
    chesterfield
    Re: Gearbox issues
    well had another play with this little prob today, put the standard link onto box gave it a try and bang on, first gear a little tight but thats bought it , one step closer for mot
    Trader
    Haz's Avatar
    Re: Gearbox issues
    if its a lil tight then just adjust it more. i've used the b&m short shift and after alot of reducing the ball on the end of the small linkage rod, ended up puttin the original back on wth the short shift lever.
