Hi guys ive got a problem with the car not charging properly, ive just had a brand new battery fitted and ive tested the battery with a voltmeter and with the car off and the reading was 12.5v and when the cars started on idle it drops to 12.2v .Ive had the alternator taken off and tested at a starter and alternator place and they said it was charging properly, and ive replaced the alternator with an old one that I was using before I replaced to an up rated one and the reading it still the same, ive also tested using a different battery, ive disconnected my amp wire from the battery incase it was this that was draining the power but still the same, the only things that have changed on the car in the last few weeks is the battery and replaced the starter motor. Any help much apreciated
