Re: Pipes
Yea got that but cant work it out still cheers
Look-Out
Re: Pipes
The long coolant hose in the first pic goes from the turbo bottom water outlet to the carb base front outlet
The 2 "V" outlets on the carb base, the front one goes to the turbo (as stated above) the rear outlet connects to the back of the inlet manifold with pipe number 10 in the samco pic
The crazy copper pipe contraption , should go from the turbo top outlet to the side of the waterpump
The oil pot in the first pic sits in a bracket next to the waterpump, the 2 breather pipes that come off it link into the rocker cover and inlet manifold
Look at these 2 if your stuck
http://homepage.ntlworld.com/carolyn...0page%201.html
http://homepage.ntlworld.com/carolyn...r%20hoses.html
Hope this helps
Re: Pipes
Thank you very much - I was looking at the diagram posted above, but as mine are so old and look a bit different we werent certain and didn't want to put them in the wrong place. Thanks for your help!!!!! Can finish the car off now
