Any body have any tips on what to use to soak carb bit's in to clean em up, figured will try this as i've stripped it 3 times and cleaned it out with carb cleaner but still don't run properly !!
Ideally once you've clean it need to blow the body out with an air line, makes sure all the crap is out if it.
is it worth soaking it in something over nite or for a couple of hour's ?
looks like i best go petrol shop and get me some jungle juice !!
i soak mine in coke
i been told that's bad because all the cyrup gets in everything.....
