Results 1 to 9 of 9
    Feb 2009
    oxford
    fueling issue
    ive just started the car for the first time since doing bigger turbo and injectors ect ran for a while then fuel started to come out of the downpipe any ideas
    Honorary Member Miller's Avatar
    Mar 2002
    Dalry
    Re: fueling issue
    What injectors have you fitted?
    Have you made a hole after the MAF to trick the ecu?
    You would be best to ask scoff or haz as to what size you would need.
    Regards
    Chris
    Feb 2009
    oxford
    Re: fueling issue
    tjhere off a bigger volvo about 300cc each ive not mapped ect yet just wanted to get it running first not sure if the chambers should fill up like that though and spill out the exhasut
    Trader
    Nocturnal Developments
    Haz's Avatar
    Re: fueling issue
    Quote Originally Posted by reevio View Post
    which ones? the greens? have you fitted the resisitor pack as it'll blow the outputs if not and injectors stay fully open everytime the ecu is turned on.
    easiest way to trick the ecu for starters is to use a dv sized take off pipe between air filter and turbo
    Feb 2009
    oxford
    Re: fueling issue
    resitor pack tell me more
    Feb 2009
    oxford
    Re: fueling issue
    ive popped the rail and injectors off the engine and they are firing constantly on turn over any ideas ive even swapped the injectors back to the standard ones and its doing the same and replaced the small length of wiring loom
    Feb 2009
    oxford
    Re: fueling issue
    just changed over my ecu the jetronic one and its sorted out the problem nice easy fix
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: fueling issue
    ah, if its firing constantly you've probably blown the outputs in the ECU.
    check that you are not using low impedance injectors without a resistor pack - you will blow the new ECU too if you are not carefull. you must use high impedance injectors, or low impedance with a resistor pack.
    Feb 2009
    oxford
    Re: fueling issue
    They are 2.4 ohms across the injectors
