failed emissions with a leak on the joint at the back box ,i have taken
the whole system out ,cleaned up and put it back together with zorst
assembly paste ,as soon as i start the engine up ,drops of water started
coming from behind the back box
thinking its a corrosion issue ,cleaned up the area to see a very neatly
drilled 3mm ish diameter hole , looks really like a factory jobbie
anyone know if its supposed to be the for water draining purposes ??
or do i just stick a screw of the suaitable diameter to fix it ???
