Results 1 to 35 of 35
    Oct 2003
    how far can you go with the stock cam?
    how far can the stock cam be pushed? whats the fastest qm trap speed had on one? ive maxed out the float chamber in the carb before reaching full dyno results, tho im now working on my second fuel supply to try and cure that
    Trader
    GT Turbo Spares co.uk
    South East Regional Rep
    phase i 16 v turbo's Avatar
    Jan 2001
    Morden
    Re: how far can you go with the stock cam?
    RS250Nut did quite well on his last build
    Oct 2003
    well i got doing 106mph terminals in a 5 with the stock cam, we went for big boost on the dyno but couldnt get passed 4500rpm in 4th but was looking very good for well past 200bhp, would love to see how fast u can go on the stock unit, think someone mentioned ages ago that 108mph has been the fastest trap on a stock cam tho i could be very wrong?
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    I think ant @ backyard managed 108mph. I've never seen more than that! you find the stock cam will make as much torque as you like, so it might have looked great at 4500rpm but they just won't breath at high rpm's once boost gets lairy.
    Oct 2003
    ahh cool so not much left in it then, could it be timed differently or is it not worth the agro?
    Apr 2002
    Dare I say Roly, from GT Tuning.....
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    I try to only use data from reliable sources If he really did (which I'm not sure I believe ?) then he did well, but he won't have been able to do it on pump fuel, I'm certain of that.
    Oct 2003
    Explain?
    Apr 2002
    Explain?
    He reckons he ran the standard cam, when he set his time of 12.6 @ 112mph.
    Non-member Karlos's Avatar
    Apr 1999
    Leeds
    He's got a T-Shirt to prove that the proof is in the pudding
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    i remember that,always bangin on about the oe cam...
    Oct 2009
    mine ran 14.2sec at 100 mph standard cam
    Mar 2004
    Salford (manchester)
    Ballocks.... just cant see that trap do able with OE cam
    Oct 2003
    so if im pushing the stock cam 108 is the goal? im sure i read somewhere about retarding or advancing the cam to move the power band, has anyone tried it with the stock cam?
    Mar 2004
    I think the most we managed was 109, this was with stock cam timing, t28 25psi, 30hp (there abouts) Nos gain...
    You can shift the cams power band by advance or retard yes..
    Heres somthing that mite interest a few, ive tried both extremes on a car running a t28 25psi, piper 285, 25hp gain.. same weather conditions/same day, same rpm and gear changes.. fully advanced fastest trap was 106mph, fully retard 116mph.. Im not saying fully retard is away to go at all you must dial your cam to suit its spec and use, this was just a practice lesson i wanted to know.. Wish i saved the ticket to see the 1/8 i really cant remember..
    Non-member rs250nut's Avatar
    What I thought to be a 260-270 piper from k-tec was a standard cam and I managed a 108mph pass
    might have gone a bit quicker too if I had not of bottled it with the boost
    Oct 2003
    so would you try the same with a stock cam? and what would you retard it too for top end power?
    Tipton
    isnt 4deg about right?
    Oct 2003
    duno sparkie, ive never done any cam work atall, how would i do it, put a vernier on on can i just jump it one tooth back?
    Non-member TommyB's Avatar
    Bedford
    My best so far is 108.21.
    That was with nitrous.
    Oct 2003
    How many teeth are on the cam pully?
    Non-member Logg's Avatar
    Didn't Colin say ages ago if you use the stock pully the wrong way round it'll retard the timing by a couple of degrees? or was it advance bloody hell I can't remember!
    Non-member markey b's Avatar
    Bury St Edmunds
    13.8 @ 105mph with stock cam and road tyres, but hoping to get better this year as my driving was appauling when i got that
    Oct 2003
    I'll give him a shout and find out
    Oct 2003
    So what way is advance and retard, clockwise and anticlockwise on the cam are what? If I twist the cam clockwise does that make it advance?
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    yes, turning the pulley over will give about half a tooth of adjustment. It's up to you weather you choose to advance it half a tooth or retard it. I don't think there will be a lot to gain with the standard cam, but definately worth a shot, if only to see what happens
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    retard would be to turn the end of the camshaft anti clockwise with the pulley stationary. Or, moving the outer of the pulley clockwise while the cam stays still. Count the teeth on the cam sprocket, divide 360 into it, then divide by 2 to get into crank degrees. One tooth will be quite a bit, I think half a tooth retard will be worth a try.
    Oct 2003
    It's more to see if I can move the powerband higher in the revs, plus Its stock bits so only cost me my time
    Oct 2003
    10.5 ish degs per tooth, so if flipping it gives half a tooth advance? I could flip it and and jump it one tooth back to give 5 degs retard? Or have I just confused myself?
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    yes, thats it.
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    except I just spotted I wrote that wrong You count the teeth, divide 360 into it to get cam degrees. Multiply by 2 to get into crank degrees, not divide half a tooth is quite a bit of timing still, you want a vernier really.
    Oct 2003
    Are there the same amount of teeth on the crank pully and cam pully?
    No there are less on the crank pulley
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    engine's 101 no, half the teeth on the crank, so twice the rotational speed.
    Oct 2003
    What an idiot, had that convo already today, cheers scoff, if the weathers ok I might take a look this weekend
