Turbo pressure testing?
I'm in the middle of redoing my turbo conversion on my clio and am just about to fit the turbo. It has a gt28r comp housing along with bolt on adaptors so I can connect my boost pipes.
I figured it would be a good idea to ensure they were sealed correctly so I placed my hand over the comp intake and then blew into the comp outlet and I'm shocked that there is a tiny air leak. I got my mate to blow into it for me so i could have a listen to see where it's coming from and it's coming from the oil way outlet.
Is this normal? as I don't have my old turbo to compare it with.
It really is a tiny air leak, and you have to blow really hard to get it to leak, how many psi can a 30yr old pair of lungs produce?
Cheers
Steve
Re: Turbo pressure testing?
i tried blowing into my tyre gauge the other day random i know max i could get was 4-4.5 psi so not much im guessing looks like the leak would quite big if you had some deacent pressure behind it.
Very Random, but it's certainly cheered me up
Motech
Your oil pressure is going to be much higher than the air pressure in your compressor housing. Once the engine is running the turbo will be spinning on a thin film of oil, air wont leak there but possibly a small amount of oil will pass in and be burnt but this is normal. excessive amounts will be obvious.
Cheers for the replies chaps.
