Results 1 to 12 of 12
    Non-member sphinX's Avatar
    Feb 2005
    Telford
    Minty83
    Is what RTOC is all about and why my registration fee was always worth it Has taken time out of his own busy schedule to come and help me sort out my blown head gasket.
    Took everything apart and put it back together again for me. Top man!! Also learnt a bit more about the engine which was good. Just need to get a decent tool from halfords to get the sump off as it was on WAY to hard and the old door handle trick didn't work.
    Anyway minty83, cheers for everything
    Oct 2004
    Somerset
    Re: Minty83
    , paul is a nice lad , well done mate, has too many cars though, couldnt be like it myself........
    Non-member minty83's Avatar
    Nov 2005
    Shrewsbury
    Re: Minty83
    Not a problem dan, like you said its what the clubs all about.
    Matt the collections thinning out now, twin engine clio sold and exige... deposit recieved and collection next week giving me time to focus on the vag twins
    Long live the RTOC
    Re: Minty83
    Quote Originally Posted by minty83 View Post
    Long live the RTOC
    Bored of the exige already
    Feb 2005
    Telford
    Re: Minty83
    You can't get bored of that monster mate you can only get scared for you're life...which is probably what happened to him haha
    Nov 2005
    Shrewsbury
    Re: Minty83
    yep just bored of it really.. rather the 5 anyday
    Feb 2005
    Telford
    Re: Minty83
    I have to bump this again. Had a few teething problems with the car once everything was back together, turned out to be a loose wire on the starter motor, which I am proud to say I fixed but then I became a drama queen when I failed to bleed the system and the temp flew up.
    Minty came to the rescue, bled the system properly, sorted out the accelerator cable and things around the carb that could be better. Top man
    Dec 2009
    west midlands
    Re: Minty83
    wat was up with you accelerator cable Dan as im having a few issues wat u do to sort it.
    Nov 2005
    Shrewsbury
    Re: Minty83
    Quote Originally Posted by Mathew Hall View Post
    it was to slack and the peddle wasnt at the top
    Dec 2009
    west midlands
    Re: Minty83
    same as mine iv sorted the slack pedal now but the revs dont seem to come down quick enough as the spring isnt strong enough iv replaced it to but iv cut my old one to make it shorter just gotta see if thats works.
    Any suggections if it doesnt.
    Re: Minty83
    A new Genuine Renault spring would prob solve it along with maybe freeing up the thottle butterfly abit with a small amout of grease / wd40 maybe it has got stiff over time and thus making it sticky or slow to respond.
    Dec 2009
    west midlands
    Re: Minty83
    well i got a new spring off Mike phase 1 and it hasnt work im gone try my modified old one tho next and if used alot of wd40, ill sort it.
    Thanks
