Results 1 to 11 of 11
    Jun 2006
    Bournemouth
    master cylinder swap
    ok so i have the great job of doing this this weekend but has anybody done this before and if so any hints or tips for a master cylinder swap virgin ?
    Non-member Nayls's Avatar
    Weymouth
    Re: master cylinder swap
    m/c is pretty straight forward,it's the servo that's the ballache!
    Classifieds Moderator
    Mar 2004
    master cylinders not the worry, how are your bleed nipples?
    i have some braided lines to go on, but i dread them fecking nips
    Non-member markey b's Avatar
    Bury St Edmunds
    i did mine recently, but admittedly the head was off.. just get a decent brake pipe spanner, avoid a regular spanner if poss as it'll just round off the soft couplings
    Jun 2006
    Bournemouth
    what size are the unions , i've got 10mm in my head but im not 100% sure
    Look-Out Kris M's Avatar
    Apr 2006
    Swindon
    Me too, i thought id soak the bleed nipples the night before in WD40 etc.......jacked the rear of the 5 up and there were no bleed nipples at all ! , some monkey has been there before me
    Non-member Tiny Tim's Avatar
    Oct 1999
    Bournemouth
    Just get the beers on ice bitch. We'll nail it.
    Oh, and this is a Clio peeps, not a 5... as someone forgot to mention
    Apr 2006
    Swindon
    Whats it doing in this thread then ???
    Jun 2006
    Bournemouth
    ok the m/c is the same as a 5gt turbo soo neeerrrrr to you tiny ! Well with the help of Tiny Tim the brakes are all fitted , the master cylinder is fitted and new brake fiuld in as well , the result ..... I'VE GOT ****ING GREAT BRAKES AGAIN ! Once again Tiny you are a leg end !
    Oct 1999
    Bournemouth
    Well, I aint got time to go to your funeral... I figured it easier to hep you with the car
    Jun 2006
    Bournemouth
    well once again thanks mate your a true mate ! Just got to get the engine swapped then we can rebuild and restore the 11 for you
