Results 1 to 21 of 21
    Non-member philg's Avatar
    Aug 2009
    Newcastle
    alloys offset question
    Right I'm starting to look out for some rims for the car, i fancy some 16" for the road.
    I used to run 205 40 16s on a 7.5x16 but can not remember offset.
    Question is does the offset stay the same the larger and wider the rims get? I know et35 is about right, does that apply to a 15" and 16" rim and what happens if you go from a 7x16 to a 7.5 by 16 does the et still stay the same with the wider rim.
    I would imagine there would be a different et for a wider rim on the same size alloys, if you get my drift.
    I really fancy some borbet a's which unfortunately come in a et20
    Cam someone explain the maths behind it and advise me
    phil
    Member clee's Avatar
    Derbyshire
    Re: alloys offset question
    It's all very straightforward but ...it depends how the width is quoted .
    http://www.1010tires.com/WheelOffsetCalculator.asp
    Oct 2009
    i had 195 40 16's not sure of offset etc but was fine no rubbing nothing
    Aug 2009
    Newcastle
    Quote Originally Posted by fcdgary View Post
    how wide was the rim?
    Oxfordshire
    ET35 will always put the tyre tread in the same place irrespective of rim width and diameter. ET20 will move the tyre tread 15mm outboard. It's more a question of what rubs where.
    7" = 178mm
    178/2 = 89mm
    et 35 puts 89+35 = 124mm in from mounting face
    and 89-35 = 54mm out from mounting face
    7.5" = 190mm
    190/2 = 95mm
    et 20 puts 95+20 = 115mm in from mounting face
    and 95-20 = 75mm out from mounting face
    make any sense?
    Oct 2009
    not sure 7,0 i think was oz superlegra
    Oxfordshire
    yep, they'll be a 7
    Oct 2009
    there you go at least someone knows
    Aug 2009
    Newcastle
    7" = 178mm
    178/2 = 89mm
    7.5" = 190mm
    178/2 = 95mm
    make any sense?
    hell no
    Derbyshire
    typo on the second set of figures
    190/2 =95
    ET is the offset from the wheel width centerline
    Aug 2009
    Newcastle
    so say you were buying 16 inch wheels, option 1 7" option 2 7.5" if you bought with the same et ie 35 for the gt, so on the 7.5" you would have 6ml extra rim on the inside of wheel and on the outside as opposed to the 7"
    phil
    Oxfordshire
    Quote Originally Posted by philg View Post
    phil
    correct
    Aug 2009
    Newcastle
    so if you had on 16s 7" wide et 35 and only had say 4 ml clearance to your strut, then a 7.5" wide wheel of the same et would rub, would you then get a different et of a smaller number say a 30 to get them on?
    Oct 2009
    lost me phil . i think perfect for five is 195 40 16 and i had 7.0 wide wheels no point over strectching rubber unless a show car but not sure how well car would cope on road. what look you after and what purpose for car??
    Aug 2009
    Newcastle
    i want these 16" but come in the wrong offset
    Oxfordshire
    possibly, it depends where you measure the 4mm. If it was the rim that was close, then yes.
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Thats a nice 5, whos is it?
    Jul 2009
    winchelsea beach
    it all depends on the design of the alloy which will effect the et
    use this http://www.alloywheels.com/
    select your car and model an size of alloy you want to use and it will show u the alloy plus the et for that alloy as well
    Oct 2009
    how come they on a five but you cant get them then???
    Oct 2009
    ronals or borbets i think are amazing on a five or go williams 15's sprayed graphite grey
    Aug 2009
    Newcastle
    They are markey b's brothers car, he had to get the wheels machined to fit.
    phil
