Anyone know where you can get the throttle cable ends.
Carb end part?
Just thought i'd ask.
Carb end part?
It slides in to number 14
Paul do you know the number for a throttle cable kit??
Thanks
The throttle cable kit from GSF had several differant end fittings including the right one for the 5.
thats come with a kit then....its a long tube with a flat end....
7701349815....were about £20
Paul B is the man!
Another for you, campus rear side window rubbers
Fixed type.
Do you know the numbers?
Thanks
7700758095 o/s
7700758094 n/s
about 70 notes.....ouch
To get you out of trouble you can use a chocy block (the connectors elections use), strip the plastic outer casing and then put the end of the throttle cable in and screw it down.
im running a secret mod known to the berkshire massive as the hot iron plug mod... as no chocolate blocks were handy marc aka carcrash and i ripped the brass earth of my hot irons plug and cut it to lenth. i wasn't that keen, but its adjustable, has worked fine for weeks, its cheap (if you have a choccy block or sppare plug) , and i carry a spare..
