Results 1 to 28 of 28
    Non-member dave r5's Avatar
    Aug 2009
    pitsea essex
    big problem
    hi guys
    well after 3 day of the 5 being road bound it went pop.
    i was in 5th at 5500rpm
    afr's at 12
    water temp at 70 degrees
    oil pressure at 5 bar
    and then the headgaset let go.
    uber amounts of smoke and a megga mess in the engine bay.
    found a headgasket and bolts on the shelf at wag benets so striped her down
    cleaned her up and put it back together, checked block and head every thing looked ok. so on it went
    started it up and she fired strait away and idled ok
    but ive got a very loud tapping from the top end.
    could i have bent a valve through hydrolick lock?
    why did the head gasket go?
    i only have 2 possible reasons. head lift or **** gasket
    what u rekon
    Dublin/Ireland
    Re: big problem
    u might have bent a pushrod or theres a damaged piston u missed..do compression test
    Aug 2009
    pitsea essex
    Re: big problem
    well problem solved,
    it skiped a tooth and the exhaust valves were hiting the pistons.
    so thats scrap.
    ouch
    may as wll chuck the forged pistons in
    Non-member Ricardo's Avatar
    Re: big problem
    5500rpm in 5th
    Hope you get it sorted Dave
    Aug 2009
    pitsea essex
    Re: big problem
    cheers fella,
    yeah new bits are being delivered today.
    ordering rings tomorrow so hoping to have it built in 2 weeks.
    she was going damn fast aswell, pulling like a train. wont be long an shell be back.
    blocks painted already
    heads stripped and being ported tanite
    cranks going in tonight
    have a clutch and fly wheel on the shelf
    all is good in the workshop of renolvo bits haha
    Re: big problem
    Maybe i should drop a Volvo lump in the Clio I'll pop over some time to have a butchers if that's ok with you mate
    Aug 2009
    pitsea essex
    Re: big problem
    yeah help yaself mate.
    allways welcome
    Re: big problem
    Quote Originally Posted by dave r5 View Post
    allways welcome
    PM me whenever you're over at the workshop
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: big problem
    Hi Dave
    From experience those engines don't tolerate a lot of timing at WOT. Did your mapper listen for det ? If you can somehow send me your ignition map I'll compare it with some of the B18FT ones I've done.
    Tipton
    Re: big problem
    wouldn't have happened with a c1j
    headgasket would have gone long before that.
    Aug 2009
    pitsea essex
    Re: big problem
    Hi Dave
    i cant extract the map from my ecu on my laptop fella as its not got a serial port.
    altho i could do it on the pc at home i guess. as i have the cable
    there were no sign's of det to the pistons or the head..
    just spoke to maper on the fone he said theres not alot of ignition in it but i dont understand it any way lol
    ill see what i can do and send it over
    Non-member markey b's Avatar
    Bury St Edmunds
    Re: big problem
    5500 in 5th is well over 70mph... may be your answer there!
    Non-member Spooky's Avatar
    Sep 2001
    SW PMT HQ
    Re: big problem
    ~ 110mph
    Sep 2001
    SW PMT HQ
    Re: big problem
    unless the clutch is shagged...
    Aug 2009
    pitsea essex
    Re: big problem
    its 104 mph in 4th at 6500 rpm
    Aug 2009
    pitsea essex
    Re: big problem
    big problem part 2
    measured up my forged pistons last nite,
    realised there too big for the bore
    then realised i threw the old rings away
    prima racing can get rings but 2 weeks wait total price to bore and supply rings £200-£250
    ctm can bore and match sum rings £220 ish
    who else shal i call.
    i cant see it being track bound buy april 9th
    Non-member modfather's Avatar
    Re: big problem
    how about ktec racing
    Aug 2009
    pitsea essex
    Re: big problem
    erm may b not lol
    ill stick to local engineering firms
    Non-member IANMM's Avatar
    Sedgley
    Re: big problem
    this is who i got my rings from for my steel liners
    http://www.fpsdistribution.com/
    Non-member 5teve L's Avatar
    RH12
    Re: big problem
    CTM mate
    Aug 2009
    pitsea essex
    Re: big problem
    yeah spoke to ctm originaly i tried big jim racing but no answer so ill try agen in a bit
    Dec 2004
    Aylesbury
    Re: big problem
    Where did the forge pistons come from mate?
    Are they same design as the standard Volvo piston other than just abit bigger bore
    Aug 2009
    pitsea essex
    Re: big problem
    i bought them from speebly mate
    but there from a prima racing engine.
    made buy arias retail at £700 ish fella.
    Dec 2004
    Aylesbury
    Re: big problem
    Ouch!
    Might keep in mind for future though but i am tempted to go slightly bigger capacity after a while if i find i need to.
    Aug 2009
    pitsea essex
    Re: big problem
    same crown design
    just a difference in the skirts i beleive
    Non-member r5 rich's Avatar
    Romford, Essex
    Re: big problem
    big jim racing??
    Non-member Kenobi's Avatar
    Jul 2006
    Leicestershire
    Re: big problem
    Ouch!
    I shall attempt to see what that is at trade for ya Marky.
    Aug 2009
    pitsea essex
    Re: big problem
    finaly made progress
    blocks being delevired to a firm in kent on friday
