Results 1 to 6 of 6
    Non-member alex-r5's Avatar
    birmingham
    1.8t vw in a 5
    right ive managed to get a vw1.8 turbo engine, gear box and all the outher bits and bobs from under a bonnet of a passat and i want to put in my 5. has any one got a a ruff to do-list on this as i no it has been done before. any pics and info would be a great help.
    Look-Out Kris M's Avatar
    Apr 2006
    Swindon
    Re: 1.8t vw in a 5
    scotland
    Re: 1.8t vw in a 5
    thats a nice conversion and you can get alot of power from these engines.
    Non-member minty83's Avatar
    Nov 2005
    Shrewsbury
    Re: 1.8t vw in a 5
    iv got a load of pictures on disk of the build so il dig some more out 2moro
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: 1.8t vw in a 5
    I made a folder with some basic picures of the build that I took for duncan as I went along. Here:
    http://g7wfs.sytes.net/vag_conversion/
    Passat is inline, not transverse I think, so not sure your gearbox and mounts will be much use ?
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: 1.8t vw in a 5
    I also still have the jig that I made to replicate the subframe. I don't get involved with conversions and things anymore but I'd be happy to loan the jig out for a few quid. I'd want to be sure of getting it back too ofcourse
    In short, you need to:
    - cut up a golf front cross member, with engine mount bracket, cut the cross member out of the GTT subframe and stitch one into the other. (jig provides engine mount land points).
    - cut the N/S engine mount cup out of a golf rear subframe assy, weld this into the O/S rear of the R5 subframe (again, jig helps line this up).
    - fabricate a N/S rear gearbox mount from scratch. I used a renault rubber on a custom bracket.
    - make a pair of shafts. I used audi S2 inners I think it was, with clio williams outers.
    - fit the remote cable-shifter into the tunnel of the R5.
    - its quite a squeeze getting a radiator in, the engine fills the bay up. Cross member had to be moved forward to accomodate the radiator. an intercooler is not an option.
    - Steering rack needs to move back about 10mm to clear the VW gearbox.
    - part of the bulkhead needs moving back to accomodate the turbo compressor outlet and pipework if you use the larger K04 turbo.
    - exhaust downpipe is also tricky, there is very little room to get the pipe out. 2.25" maximum without splitting into 2 pipes, or flattening the pipe, etc.
