Results 1 to 32 of 32
    Non-member MR TURBO's Avatar
    bristol
    What Fuel?????
    Quick question what fuel do you guys put in your 5's??
    Non-member Adam 005's Avatar
    Dorset
    Re: What Fuel?????
    97 ron and above if pos.
    Non-member EDM's Avatar
    Chichester
    Re: What Fuel?????
    anything 97 ron or above for me, except tescos super- car runs badly on that for some reason.
    Mar 2004
    Salford (manchester)
    Re: What Fuel?????
    My fastest run at pod was on tesco super (with my additive which i allways seem to use ) ... but normally i just use shell optimax 98 ron i think???
    Oct 2007
    costa del walney Island NW
    Re: What Fuel?????
    have always ran mine on normal unleaded no probs so far done 10k easy......
    belive i read somewhere you get better performance on....leaded
    am going to start running leaded shortly to see if theres a difference, there is a suplier local enough
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: What Fuel?????
    why would you need leaded ?
    Oct 2007
    Re: What Fuel?????
    i read from and old topic on RTOC not to sure about ins and outs ...
    please reveal your findings
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: What Fuel?????
    no findings as such, nothing really to find you don't need it. the latest leaded fuel had only tiny ammounts of lead in it anyway, much less than was common when your car was made. your valve seats are not so poor that they need lead. they work fine with lead free fuel. there is no other gain to be had from leaded fuel so it is a waste of time and money.
    Oct 2007
    Re: What Fuel?????
    cheap unleaded fuel for now is what it is then
    Non-member Spidey's Avatar
    Lincs
    Re: What Fuel?????
    Anyone ever used AVGAS?
    Might be worth a try, I can get some if someone wants to try it....
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    Re: What Fuel?????
    Unless you ramp up the ignition, and/or use it as detonation suppressant for silly boost levels, there's zero gain from running Avgas.
    Non-member Shane P's Avatar
    Jan 2006
    Re: What Fuel?????
    Try the Tesco 99. My car absolutely loves it. Anything 97 and above will do the job nicely.
    I put in a gallon of 95 in once in a blue moon, but only when i have half a tank of 99 in already
    Non-member UNICRONICUS's Avatar
    Jun 2004
    Isles of Scilly
    Re: What Fuel?????
    My friend used to use Jet A-1 when he ran out of petrol, his bikes and outboards didn't like it though His old man used to (might still) supply the aircraft over here with fuel from his tanker, so when he wasn't looking....glug, glug, glug into a 5L fuel can
    Re: What Fuel?????
    I use tesco 99, seems fine. Anything above 95 ron goes in the van.
    Apr 2002
    Re: What Fuel?????
    The C1J doesn't need leaded fuel, but I tried some a couple of years back and my car ran 17 times better on it than on any unleaded. I tried it again a few months later and again, it was like driving a different car. It idled smoother, started better and pulled cleaner, especially from very low revs. When the engine was cold was when it was most noticeable. Now maybe that's just my shady car , but if I was rich i'd slap leaded in all the time. However, i'm not, so i won't
    Non-member BriC's Avatar
    Dec 2005
    Re: What Fuel?????
    I run 95 and don't have any problems.
    Loose Bolts Tuning stuTHC's Avatar
    Dec 2005
    Leeds
    Re: What Fuel?????
    I whole heartedly agree with Mr Bill of the J. Ive used 4 star three times in THC, everytime it's made such a huge difference, idle was just like velvet. But at £1.46 ltr it's not cheap. I went to put some in a couple of weeks ago thou and the garage near me dont sell it anymore, ive got a 45 mile round trip to get some now. So it gets nothing other than shell v-power now.
    Re: What Fuel?????
    I set my carb up for 95ron. 18psi good afr's. 190bhp and 179ft/lbs at motorscope. Oh and the engine is now in a 16v clio pulling 14.2 qm's on shady tyres! Its all about the fueling up to a certain point, after that i would have looked at maybe water injection.
    Re: What Fuel?????
    I also use 95 Ron Tesco stuff carb fettled and tweeked for 22psi (manifold) with really good afr's and no sign of det.
    Trader paul b's Avatar
    Jul 2002
    Re: What Fuel?????
    for day to day running I use shell optimax........
    for the trackdays and every 4th tank I use 4 star..........
    the old 4 star , not sure if its me but the 9 starts better,runs better and feels smoother.....
    but at £1.49 a litre now AND they have said they may be running out by the end of the year......we'll see how long this lasts..
    Dec 2005
    Leeds
    Re: What Fuel?????
    Is that Bayford Thrust 4 star?
    The guy at my local stockist said they have run out. He ordered the last 5500 ltrs from Bayford last May apparently. Due to lack of demand they will not be refining anymore in the foreseeable future.
    They are however apparently looking at importing around 500,000 gallon of Russian 4 star for sale in the uk, so any future supplies your garage gets may be Ruski fuel- you'll get 1 token for every 10 ltrs purchased, collect 20 tokens for a 1/2 ltr bottle of vodka, 500 tokens gets you an AK47 and for 1000 tokens you can choose from a range of depleated uranium
    Look-Out Kris M's Avatar
    Apr 2006
    Swindon
    Re: What Fuel?????
    Well the one place near ish to me that sells 4 star were charging £2.25 per litre when i called them today !!!!
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: What Fuel?????
    I'm going with shady car
    there's no scientific reason why it should prefer leaded fuel.
    Non-member EmmaB510's Avatar
    Feb 2005
    Kilwinning
    Re: What Fuel?????
    LPG prefer flogas because its cheaper but will stretch to 60p per litre when required
    Non-member rogerreno's Avatar
    RC Racing HQ
    Re: What Fuel?????
    '17 times better' LMFAO!!! Was that scientifically calculated or did it just run crap 16 times prior to putting the 4 star in??? LOL!!!!
    Your a star Bill
    Apr 2002
    Re: What Fuel?????
    Rog, it was actually 17.312 times better, but I rounded it down
    Scoffski, shady car maybe, but it seems that other's also have the same "shadyism". Science is over-rated anyway
    Re: What Fuel?????
    Have to agree with the lads. Totally unscientific - the car seemed to be 'happier' on 4star.
    Fife
    Re: What Fuel?????
    http://cgi.ebay.co.uk/RENAULT-5-GT-T...d=p3286.c0.m14
    Surely for 30 notes this cant work!
    Anyone had any experiences?
    Banned
    kinglassie, scotland
    Re: What Fuel?????
    is loyods bank no bust ? lol
    Fife
    Re: What Fuel?????
    Quote Originally Posted by Mike Wilson@ PCS View Post
    Not yet, i don't think. But probably will be if folk start buying this rubbish,
    May 1996
    Pie & mash shop
    Re: What Fuel?????
    Fife
    Re: What Fuel?????
    Exactly my thnking!
