Results 1 to 22 of 22
    Oct 2004
    Somerset
    rev limiter wiring
    hi peeps , im goin to attempt this myself...., was just wondering where on the aie i connect the ole girl up?, its a lumenition rev limiter, i think they all wire more or less the same anyhows, cheers , jeez.
    bracknell
    Re: rev limiter wiring
    your limiter should have come with destructions
    but if it didnt its `easy
    first remove the aei unit
    second remove the coil from the aei
    third were the coil connects to the aei cut away at the plastik so that the wires from the limmiter can be pluged in
    Oct 2004
    Somerset
    Quote Originally Posted by THE MASTER View Post
    Cheers Col`, i hoped youd answer as you were on, ta bud, ill be doin just that later on then...
    Oct 2004
    Somerset
    Col, sorry bud , do you mean on the coil its self or the aie......man im thick sometimes...
    Look-Out Kris M's Avatar
    Apr 2006
    Swindon
    The coil is attached to the AEI Matt
    Oct 2004
    Somerset
    Quote Originally Posted by Kris M View Post
    Yeah but it comes off, a couple a screws etc etc....
    bracknell
    undo the two 20 torx srews and pull the coil away from the aei
    Oct 2004
    Somerset
    ...col, where is the plastic i cut too exactly....
    bracknell
    as or when you pull the coil away from the aei youl see two connecting posts (round)(yes they are marked pos an neg) carfully cut awy the plastick on the aei so that you can get the lim connectors to slip on from the out side.
    cant be a**** to do pickys as i have propper man flue
    Oct 2004
    Somerset
    Cheers Col`, as i said in pm..., hope ya get better soon buddy
    Oct 2004
    Somerset
    Just out of interest , those of you with rev limiters what have you set them @ , im running standard boost, whats reckon i set mine @?...
    Non-member Sy5GTT's Avatar
    Mar 2006
    Deepest Wilts
    Matt empty your inbox
    Oct 2004
    Somerset
    Quote Originally Posted by Sy5GTT View Post
    Sorry sy......
    Non-member markey b's Avatar
    Bury St Edmunds
    set it to 9k, but try and avoid hitting it...
    mine is set to 7k, but i rarely hit it as it doesn't make much power after 6500 anyways
    Oct 2004
    Somerset
    Damn mark , how did you know...., thanks to col an bruce , i sorted it and it works a treat and ive set it @ 6500 like, so good guess......9k, whats your name...adey...
    Bury St Edmunds
    i thought it was sparky that likes the larger rev limit
    Oct 2003
    i have quite a conservative 7500rpm limit ill have you know, tis getting upped tho as the powers still climbing as it hits the limiter
    all working now jesus?
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    Quote Originally Posted by adey Aka Ewok View Post
    tis Getting Upped Tho As The Powers Still Climbing As It Hits The Limiter
    R11410
    Oct 2004
    Somerset
    Aiiiii`, all doin its thing ade , its quite a smooth cut too which is nice..
    Non-member GTphil's Avatar
    just make sure your wiring is sturdy an up to the job, the live wire fell off my limiter, you can guess what happened next! had a bit of a play with a starlett gtt didnt watch the rev counter, one bent valve, cracked guide, fubared piston! gutted took me two full 12 hour days of hard graft and a few quid thanks to some **** wiring!
    Oct 2004
    Somerset
    Ouch phil........., yeah the wiring in A1 buddy...err {i think..}
    Non-member Junglist's Avatar
    Dec 2008
    Chester
    Holy thread revival!
    This really helped me today.
