Results 1 to 9 of 9
    Tewkesbury
    idleing wrong
    i cant get my 5 to stop idleing up and dwn and it wont start without a chock on
    bracknell
    Re: idleing wrong
    could be the co screew missing
    Tewkesbury
    Re: idleing wrong
    wot screw
    Look-Out Kris M's Avatar
    Apr 2006
    Swindon
    Re: idleing wrong
    The co (mixture screw)
    Tewkesbury
    Re: idleing wrong
    where is it on the carb then
    bracknell
    Re: idleing wrong
    Quote Originally Posted by mezza85 View Post
    its at thebottom and points up at an angle (drivers side)
    Tewkesbury
    Re: idleing wrong
    cheers mate for that ill have alook later
    Oct 2007
    costa del walney Island NW
    Re: idleing wrong
    bad fuel pressure, dodgy diaphragm in carb. air leak on one of the vacume pipes/dumpvalve leaky.
    after i removed my dump valve for good the idle ing rose up quite a bit, try removin them and blanking the holes and removing t piece and vacume pipe and replace with straight connector
    make sure no other air leaks
    Tewkesbury
    Re: idleing wrong
    ill try that m8 thanx
