Results 1 to 10 of 10
    Non-member sphinX's Avatar
    Feb 2005
    Telford
    Confused
    Right after some spirited driving yesterday i have noticed that my boost gauge is weird.
    Before, at idle, it would sit at -5 and go up to 21 on boost. Now it sits between -5 and 0 and boosts up to about 18...I have no idea whats happened...any one shed some light please? Car doesn't feel any slower either
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: Confused
    Could be a leak in your vacuum (boostgauge) pipe - I'm guessing the same pipe goes to your ignition module and dump valve, if fitted.
    Check for leaks in all of it and if you have a dump valve check that the diaphram isn't split.
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    Re: Confused
    Sounds like a leak post-throttle side. Check the 2 gaskets & plastic spacer that the carb sits on, and that the lower half of the carb is fully tightened to the body.
    Also check aei vacuum line, vacuum capsule, dump valve (if one fitted), boost gauge (if one fitted).
    If that's all ok, check anti-perc fan sensor is screwed in tight on the throat of the inlet manifold, and that the 2 nrv's at the back of the manifold are tightened up. Could also be the start of the manifold gasket on its way out.
    Feb 2005
    Telford
    Re: Confused
    thanks, will check tomorrow morning
    bracknell
    Re: Confused
    i like simple cheacks
    are all your manifold nuts inplace and tight
    Feb 2005
    Telford
    Re: Confused
    Still no joy, spent a while 2day looking around trying to find a problem but no idea what I'm looking for really. I checked the boost hoses and dump valve and the boost gauge (i think). I will have to look again 2moro and dig deeper.
    Non-member minty83's Avatar
    Nov 2005
    Shrewsbury
    Re: Confused
    Quote Originally Posted by sphinX-B17GTT View Post
    Thats what happens when you try messing with the vag
    Feb 2005
    Telford
    Re: Confused
    haha you git! I blame you for bringing out desperation from my engine lol.
    Feb 2005
    Telford
    Re: Confused
    fixed, dump valve was shot
    Non-member 5teve L's Avatar
    RH12
    Re: Confused
    As Chris said
