hi guys i need some info on the Clio mk1 i was told that the r5gtt sub frame fit the clio and is not so hard ti fit the c1j in it is that true any help pls
the 5gtt subframe doesnt fit the clio as the front legs dont reach.
You can use the clio subframe ..all you need to do is drill a hole for the gearbox mount at the front and the engine fits.
Ive done this conversion and so have many others if you wish for more advice
im pretty sure they are the same as the clio16v brakes ..somebody will correct me ..if i were you id upgrade to at least clio 16v brakes. As the 1.2/1.4(assuming the clio is a 1.2/1.4 lol) brakes arnt that good
Wiring wise ...i used the clio loom ..but i cant remember how it all went together as miller on here did that loom for me. Im sure there will be advice from the other clio gtt owners soon for you
You will have to use clio shafts ...i used the clio 1.8 16v running gear and brake setup on mine as they are stronger than the 1.2 ones
And cheers for the comments ...ive not updated my pics for a while ...ive been spending a wee bit of cash on my engine recently
yeah they fit the 5gtt box as i was running this gearbox before hand ...i changed mine back to my 1.2 box as i didnt have the speedo setup for the 5gtt. I only did this as i wanted a speedo
The R5 GTX Gearbox is cable drive.
