Results 1 to 21 of 21
    Dec 2009
    west midlands
    Rad weld
    iv recentley changed my radiatior as it was shot and all my hoses seem to be good, but i am still getting a couple of spots of coolent after pulling up and leaving a board under the car overnight.
    It could be possible the rad Has a slight leak, wat are if any the dis-advantages of using "RAD WELD"
    Would you use it.
    Thanks
    Member Woznaldo's Avatar
    Canberra, Australia
    Re: Rad weld
    Rad weld is an emergency only solution for the 5. It will stop small leaks but will clog the waterways, like fat in an artery. When I got my 5 it had rad weld in it and all it did was constantly overheat!
    Short answer: NO.
    Re: Rad weld
    Was the replacement rad a new one or a 2nd hand one? If it's new, is it a copper cored one or an OE item?
    If it's new and OE then it's unlikely that there's a leak, but it has happened to folk.
    Not many here would advocate the use of Rad Weld. Better to persevere and try and ascertain where the leak is coming from. IMO.
    Kent
    Re: Rad weld
    Ram a cork up your japs's eye and try and take a piss, that's what your coolant sytem will feel like with radweld in it....Heh!
    Get it pressure tested.
    Dec 2009
    west midlands
    Re: Rad weld
    looks like i wont be using rad weld then. It is a brand new copper core radiator so it shouldnt be leaking but is a possibilty, it would have eliminated the radiator if i could have used it as i cant seem to find the leak anywhere in any of the hoses.
    I will be able to have a better look the weekend as its too dark wen i get back from work, i was just seeing wat peoples thorts were on rad weld.
    Hopefully its just a hose or the clip securing the hose.
    Non-member DaveMayGTT's Avatar
    Fareham
    Re: Rad weld
    copper cores are well known for leaking, standard rad is the way forward
    Oct 2003
    Re: Rad weld
    i had a brand new coper core one split between the oil and water ways, worth checking it out, gsf replaced mine no questions asked
    Dec 2009
    west midlands
    Re: Rad weld
    mine is also from gsf, wat do you mean it split between the water and oil lines, where did you notice the leak was coming from as i havent seen any sign of where its coming from but will definatley have a better look the wek end.
    Thanks
    Non-member Ricardo's Avatar
    Re: Rad weld
    Pressurise the system, you'll soon find out where the leak is
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    Re: Rad weld
    2 good rules of thumb already mentioned in this thread - Never ever use RadWeld on these engines, and a standard rad' is the way forward.
    Dec 2009
    west midlands
    Re: Rad weld
    well i did that b4 i changed the rad and it made it alot worse and dont really wana be doing that.
    I will see how i go the weekend and give an update to where i stand.
    The barsteward thing i was hoping the leak would have gone after chanhing the rad.
    Non-member TrixNFlix's Avatar
    Preston
    Re: Rad weld
    Quote Originally Posted by Mathew Hall View Post
    Yeah, but thats the idea, so you can see where the leak is,
    Seriously though as Ricardo says pressurize the water system, this will save you alot of time.
    Apr 2002
    Re: Rad weld
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    Re: Rad weld
    Dec 2009
    west midlands
    Re: Rad weld
    standard rad is the way forward, why is this id have thort it wouldnt be able to cool the engine down well enough unless the rest of the car is standard.
    Apr 2002
    Re: Rad weld
    Where did you get that idea from? A tuner buy any chance, who just happens to sell copper ones as "uprated"?
    Non-member hydrotec78's Avatar
    Hartwell
    Re: Rad weld
    I hate rad weld ! Altough it dose earn me lots of money saying that i hate copper core rads to Go for a alloy rad, Great for heat transfer and they look good aswell !
    Dec 2009
    west midlands
    Re: Rad weld
    iv been looking at those alloy ones on ebay from China 4 like £100 i assume their the ones you mean.
    will one of these fit with a front mount intercooler and wat about fans as they dont come with one and also how about your oil lines does that mean i would hace to buy an oil cooler too.
    Re: Rad weld
    Mate, pay a little extra and try and find a valeo rad for the 5 then you wont have to worry about seperate oil coolers and all that malarky!
    Dec 2004
    Aylesbury
    Re: Rad weld
    Yes if you fit one of those alloy rads you will need an external oil cooler too, you can use your original rad on it.
    If you don't want to go with the expense of an oil cooler then i'd go standard all day, more than up to the job at any state of tune that your engine maybe.
    Non-member sphinX's Avatar
    Feb 2005
    Telford
    Re: Rad weld
    valeo
