Results 1 to 7 of 7
    stevenage
    Wish bone bolt part numbers
    Hi all,
    I'm after part numbers for the both sides. Wish bone nuts and bolts plus bottom ball joint nuts and bolts.
    THANK YOU
    p.s I was also wondering if renault still do the bonnet heat matt part and what kinda price they are.
    Many thanks in advance.
    Trader paul b's Avatar
    Jul 2002
    Re: Wish bone bolt part numbers
    Bolt 7703102041
    Nut 7703032144
    Lock Nut 7703034248
    Ball Joint Bolts 7700769717
    " " Nuts 7703034247
    Pinch Bolt M10*125*48 7700763315
    " " M10*125*54 7703002735
    Jul 2002
    1) 6001021454
    2)7704000681
    3)6001006724
    4)7700710101
    5)7700710102
    6)7703102041
    7)7703053070
    8)7703032144
    9)7703034248
    10)6001021456
    11)6001006724
    12)6001009141
    13) VARIOUS
    Jul 2002
    does the above format work for everyone.....?????????
    if so, Scoff...how do I get it into the files section....LOL
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    You'd have to create a text file (use notepad or something) with the part numbers in. The problem is, you might have 10 images in a directory, so there would be 10 text files. The best bet would be to create a text file with the same name as the image name. IE:
    and
    00008703_1.txt
    So, people would find the image they want then look at the matching text file to get the part numbers
    Bit of a ballache to create them all though!!
    Jul 2002
    OK....will have too look into that......would be cool if we can add them to the files then we get an almost 100% look up ......
    difficult to sort number for phase 1 and 2 etc so I guess I'll text up the phase 2 stuff....do phase 1's to order....
    it will be a ball ache.....but long term could save me years of stress....LOL
    Member clee's Avatar
    Derbyshire
    On the RAOC site we have a searchable PDF for parts
    Not sure how it's been done but you can type a part # in and it'll take you to the page/ diagram .
    I have the GTA parts as PDF as well but it's 13mb so even zipped its huge .
    The RAOC online info is member locked ,but I have the key
    Perhaps the guys that did the PDF can help .
Size:  135.8 KBName:  result.jpg
