Results 1 to 3 of 3
    Non-member royz's Avatar
    stockport
    posting while logged into aol
    has anybody else had problems posting while going through aol. as for the last few days have not been able to post so switched to a different browser and all is well?
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: posting while logged into aol
    are you using the Live window or trying to post via the normal boards navigation ?
    the Live window uses javascript quite a lot. If you are havnig problems with only the Live window then you should check that javascript is enabled in your browser.
    stockport
    i was trying to post via the normal boards i could not work out the when i clicked post the stuff i typed went and a massage saying that minimum of 2 charcters. so i thought abot trying a different browser
