Results 1 to 34 of 34
    Oct 2003
    ph2 11 turbo
    come on then peeps in the know, suspension wise on an 11 turbo whats interchangeable with other cars? also where should i be looking for things like roll cages and strut braces, cheers me dears
    Oxfordshire
    Re: ph2 11 turbo
    very little
    Re: ph2 11 turbo
    Omp used to do an adjustable front strut brace. Koni used to make dampers for them, i imagine Gtt stuff will probably work on the front with a few pmt mods.
    As for a cage, a custom job is probably your only choice unless you make another fit, ill bet they are like rocking horse sh*t to find one off the shelf these days.
    Oct 2003
    Re: ph2 11 turbo
    hmm ok then, im thinking ph 2 gtt coilovers up front, can it be made to work in a typical pmt fasion?
    Re: ph2 11 turbo
    Yeah i reckon they will go on one way or another.
    Few bits for 11t's on ebay france like mate, silicone coolant hose kits & boost hoses etc if your feeling flush
    Jul 2003
    Re: ph2 11 turbo
    Who's got a phase 2 11 Turbo then Adrian?
    Oct 2003
    Re: ph2 11 turbo
    cough cough a friend cheers brigsy will take a poke about, in no big rush, got a few engine tweeks to do b4 i get to bothered by the brakes and sus
    Jul 2003
    Re: ph2 11 turbo
    Re: ph2 11 turbo
    Just been looking at that steve, looks sweet as
    Buy it & ill swap for this brand new gtt steering wheel im my loft
    Jul 2003
    Re: ph2 11 turbo
    I'd sell my VAG Clio to get that!! It's a little minter!!
    Always fancied a LHD Renault Turbo?
    Anyone want a VAG Clio?!
    Oct 2003
    Re: ph2 11 turbo
    u dnt wana sell that weeeee beastie
    Non-member Schakal's Avatar
    Barry
    Re: ph2 11 turbo
    you can make coilovers pmt style ,there should be
    some pics in my profile
    Oct 2003
    Re: ph2 11 turbo
    could you not fit gtt hubs struts and topmounts? cant see much in your pics bud
    Barry
    Re: ph2 11 turbo
    gtt hubs would be the same i think ,so there is no point fitting them .
    all pics of coilovers are in here
    http://s203.photobucket.com/albums/a...ult/?start=all
    Oct 2003
    Re: ph2 11 turbo
    would they be the same as ph 1 or ph 2 gtt hubs? then i could mate up with the coresponding gtt suspension
    Re: ph2 11 turbo
    Gtt ph1/2 hubs are all the same, the difference is in the bolt spacing on the strut/top mount.
    Iirc 11t is similar to ph1 strut? been years since ive seen one so may be wrong?
    Oct 2003
    Re: ph2 11 turbo
    so if i used the right combination of top mount and strut all should be fine? thats banking on the fixing holes for the tophats being the same
    Non-member Spooky's Avatar
    Sep 2001
    SW PMT HQ
    Re: ph2 11 turbo
    I feel a bit of Spookdev Tweeking comin'...
    Oct 2003
    Re: ph2 11 turbo
    Got much on sat spooky? ;-p
    Tipton
    Re: ph2 11 turbo
    the rear bushes in the trailing arms fail more frequently on these than on a gtt. beware.
    Non-member i l k e r's Avatar
    Cyprus
    Re: ph2 11 turbo
    ph1 5gt coilovers with corresponding top mounts will fit straight on.
    omp does an adjustable strut brace which doesn't fit without mods, they also do a rollcage but not sure if it's still available....
    Oct 2003
    Re: ph2 11 turbo
    Easy fix?
    Oct 2003
    Re: ph2 11 turbo
    Quote Originally Posted by i l k e r View Post
    Cool cheers will take a look around
    Cyprus
    Re: ph2 11 turbo
    Easy fix?
    depends how good you are with a big hammer
    Barry
    Re: ph2 11 turbo
    ayee omp brace is crap ,i had to butcher and reconstruct mine from scratch
    make your own brace tbqfh .
    Sep 2001
    SW PMT HQ
    Re: ph2 11 turbo
    If a GTT rear beam is the same...I have access to another Ewok
    Also, it's a date
    Barry
    Re: ph2 11 turbo
    Also, it's a date
    totally different ball game mate ^^^
    adey , put some pics up dude
    Sep 2001
    SW PMT HQ
    Re: ph2 11 turbo
    Lets hope it doesn't fall apart on me
    Re: ph2 11 turbo
    My omp brace fitted fine, as far as im aware no mods had been done.
    Rear beam bushes went on mine aswell, hard to find a good used axle!
    Oct 2003
    Re: ph2 11 turbo
    How different are they? Are the bushes the same as the gtt ones?
    Oct 2003
    Re: ph2 11 turbo
    Also, it's a date
    good stuff, be cool to get it decked and running with another 50bhp ;-p then I'll get sum pics up
    Tipton
    Re: ph2 11 turbo
    i'm not sure they are the same as the gtt, even if they were they'd be very expensive.
    Oct 2003
    Re: ph2 11 turbo
    Was thinking more for knocking a good set out of a good beam to replace the 11 ones? Tho I'm not to bothered at the mo as they seem to be in good shape
    Oct 2003
    Re: ph2 11 turbo
    ive found omp list a cage for the 11?
