Results 1 to 13 of 13
    Non-member LYNCHSTAR's Avatar
    won't start
    my car started fine this morning and on way home from work i went to fill up got back in the car then it would not start. when you turn key the starter motor don't turn and the oil light and battery light don't come on theres plenty of life in battery as lights come on and dont dim. any ideas
    Non-member minty83's Avatar
    Nov 2005
    Shrewsbury
    Re: won't start
    loose wire somewhere check the battery terminals, starter and alternater wires..
    Re: won't start
    Quote Originally Posted by minty83 View Post
    checked them mate all good
    Nov 2005
    Shrewsbury
    Re: won't start
    does the starter engauge?
    Re: won't start
    it doesent move at all not even a sound. it wont bump start and ive tryd jump leads aswell no joybrickwall
    Non-member mike's r5's Avatar
    High Wycombe
    Re: won't start
    check the earths m8 i had i similar prob it was the earth that bolts on the bulk head 2 block on the drivers side.
    Re: won't start
    Quote Originally Posted by mike's r5 View Post
    i will have a look 2 mora m8 thanx. need a beer.
    Tewkesbury
    Re: won't start
    Check the earth cable hasnt broke by the water pump i had the same problem 2 months ago
    bracknell
    Re: won't start
    could be the death block conector behind the n/s head light (main engine loom conector block) pull it apart and cheack for dirty/burnt conections inside the block
    Oct 2007
    costa del walney Island NW
    Re: won't start
    be carfull pulling it apart
    Non-member OUTLAW's Avatar
    ENGLAND
    Re: won't start
    CHECK ALARM AND IMMOBILISER IF FITTED.
    walsall
    Re: won't start
    could be the brown connector behind the heater controls i used to have same problem
    Non-member Tiny Tim's Avatar
    Oct 1999
    Bournemouth
    Re: won't start
    Need more info as to what the cars doing... sounds like its not even clicking right? If you're getting all the usual lights on the dash, then the first thing i'd check would be the TDC sensor.
