Results 1 to 32 of 32
    Non-member minty83's Avatar
    Nov 2005
    Shrewsbury
    Slicks anyone..
    since getting back from mallory iv been trying to sort my self some slicks.. in 15" only set iv found so far is some dunlop slicks but there 182+vat per corner found from tweeks, this site tho which may benefit someone
    http://www.sticky-slicks.co.uk/
    My r888 2weeks after purchase approx 300 road miles and 1hr 20 at mallory
    Re: Slicks anyone..
    yikes how much were your R888's?
    Trader paul b's Avatar
    Jul 2002
    Re: Slicks anyone..
    are they super soft R888's......
    mine are fine matey boy, plenty more left on my GG's......
    Nov 2005
    Shrewsbury
    Re: Slicks anyone..
    not super soft but soft ordered the wrong codebrickwall but still want something which will last longer than the toyo had mediums and after 20 minutes at the FCS they were doing the same sort of thing
    Nov 2005
    Shrewsbury
    Re: Slicks anyone..
    Quote Originally Posted by Andrew Warren View Post
    think i got them for 300 fitted in the end... thanks for the video andrew
    Jul 2002
    Re: Slicks anyone..
    the tyre rippling around the cuts is perfectly normal.....takes a good drive home to remove them and then they are like new again on mine.....
    the rippling is how the tyre pattern moves under cornering, its where the grip comes from and are not far behind slicks but a fraction of the price and road legal....
    i get over 2000 miles from my fronts , GG medium compounds...not tried the softs yet....YET....LOL
    Andrew, did you get my e-mail...no file attached....
    Nov 2005
    Shrewsbury
    Re: Slicks anyone..
    2000 track miles? i know the rippling is normal but i still lost about 4mm of tread
    Jul 2002
    Re: Slicks anyone..
    left hand front tyre gets a hammering at Mallory.....
    yup, 2000 track miles.....and on my 3 rd set of fronts in 2 years.....mmmm, thats why there was a petrol shortage, LOL.....
    as I say, I havent tried the softs yet...
    Rockingham too is very hard on tyres...no physical grip on track so tyres get worked hard there.....even teams who run there worry about tyre wear on slicks...
    Nov 2005
    Shrewsbury
    Re: Slicks anyone..
    fair comments there paul but if anyone can point me in the direction of some 15" slick i would be most greatful, still going to keep the r888 for road use as i feel you cant beat them..well in the dry anyway but iv got some other rims i want to use just for track
    Apr 2002
    Re: Slicks anyone..
    You could try Mark Fish. The old Clio Cups use 15" slicks and he still maintains a lot of them. Part worns are your best bet They usually come with loads of miles use left in them, and for a fraction of the price of new ones.
    Nov 2005
    Shrewsbury
    Re: Slicks anyone..
    cheers mate, have you got a link or any contact details?
    Apr 2002
    Re: Slicks anyone..
    01279 431628
    Jul 2002
    Re: Slicks anyone..
    01279 431628
    I tried clicking on the above number....nothing happened....LMAO
    Apr 2002
    Re: Slicks anyone..
    I was going to state that that was one of those old phone number things that were once used, but I thought against it. I should have known better
    Non-member car.crash's Avatar
    Aug 2006
    Re: Slicks anyone..
    all slicks are far from the same, i used euro cups before done 2 trackdays and they had hardly worn and gripped very well, only a blowout caused me to get new ones. so i then got a set of s2's they were very sticky and went slippery when hot after a good few laps and didnt last 1 trackday, so make sure you choose the right ones or they may not even last 1 trackday. also when using sticky slicky etc make sure they are matching compounds.
    Non-member steveT2's Avatar
    YORK
    Re: Slicks anyone..
    As anyone used 888's and Kumho V70's??? just curious if the V70's are any better, think they are about double on cost.
    YORK
    Re: Slicks anyone..
    Quote Originally Posted by steveT2 View Post
    Just found this, to aswer my question http://www.tyrereviews.co.uk/Article...yre-review.htm
    Looks like the 888's have it considering the price difference
    Mar 2004
    Coventry
    Re: Slicks anyone..
    Paul I found that I was getting at least 3K from the medium compounds and spend plenty of time on track. Maybe time to you to get a cheap tyre temp guauge / sensor setup? Suspect they have got too hot - past their working temp and just killed them. I could get 5K on the road with a little track use. Also dont hang about on track just in case you all think I drive like miss daisy lol
    Not been on track in the car with you but you can keep the temps down in a car by adjusting your style of driving and smoother lines. The diff / setup of the car will let you get away with some agressive lines but at the expense of your tyres.
    Be interesting to see how it does on slicks but again I feel you have to drive a bit different on slicks - just my experiances
    Hope this helps in some way
    Nov 2005
    Shrewsbury
    Re: Slicks anyone..
    Quote Originally Posted by Duncan Grier View Post
    i thought it maybe the lines i was taking but when i was following cars into the corners most cars were pretty much on the lines i was using, i might just get a set of gg for the front and see how they hold up on the ring trip
    Oct 2003
    Re: Slicks anyone..
    did you keep a check on ure tyre pressures throught the day?
    Oct 2007
    costa del walney Island NW
    Re: Slicks anyone..
    sorry to hijack thead,
    just acquired so 13" avon slicks , 9" wide.
    what are peoples veiws on these please they are very slightly taller then 13/55/13s prob could of done with being taller but "beggers cant be chooses".
    my plan is to get 4 spare steel gtt wheels and extend two of them to take these monster tyres. . . . .
    Nov 2005
    Shrewsbury
    Re: Slicks anyone..
    yes dropped it to 20 and when i finished after the mount went they were 28
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: Slicks anyone..
    Quote Originally Posted by dave j gtt View Post
    For the track or drag strip ?
    Aug 2006
    Re: Slicks anyone..
    http://www.wide-wheels.co.uk/
    these guys will stretch your steelies, they did a mates set and they came back fine.
    Oct 2007
    Re: Slicks anyone..
    oops drag strip
    do as you have with your wheels chris except these do have the same height
    cheers for that marc , but i fancy doing it myself for the satisfaction
    Aug 2006
    Re: Slicks anyone..
    i hope you know what your doing
    Mar 2004
    Coventry
    Re: Slicks anyone..
    Quote Originally Posted by minty83 View Post
    It may be worth trying a bit more pressure but that is not far off, it is more to do with temp than pressure. But pressure plays a big part. Light 800kg - 1000kg 20 - 26 psi cold 24 - 32 psi hot
    Toyo bod states 'Originally we only had one compound ‘GG’ (medium hard), but we have now introduced some sizes in a ‘SG’ (soft/wet) compound. This was done primarily for sprint/hillclimb (around 60 second runs) where the distances covered are relatively short and you need the tyres to work/heat up very quickly. This is not a compound I would recommend for race/trackday dry use as the tyres will go off very quickly.'
    Those front wheels are getting some pain with the vag lump lol
    Dont forget the extra info I posted on this thread with Alan's contact details, give him a call
    https://www.rtoc.org/boards/showthrea...highlight=R888
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: Slicks anyone..
    oops drag strip
    Ok, well the most you can get out of cutting up steels and welding them up as I did is 7.25 J, they took my 9" drag slicks OK, just
    Track tyres unfortunately don't work atall well on the drag strip, often road tyres will out perform them. You need alot of heat in a track tyre like that before it starts to get sticky. Drag tyres are alot different, they are sticky from cold.
    Oct 2007
    Re: Slicks anyone..
    tyres in the bin then *lol* on with plan to do my steelies and get some tyres later
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: Slicks anyone..
    you might find that if you soak them in grip alot and get them propper hot before a launch they might work OK
    Non-member Stuart Clark's Avatar
    Bridlington
    Re: Slicks anyone..
    Hi,
    I have a pair of 15 inch avon slicks that set me back 400 quid, as said already these are crossply and have a very stiff sidewall and are great for a track day although i have an lsd and in tight corners i found the rear doing some steering under power, quite weird and scary.... They are a 10.3/22.5 15 i think but will check, i would be happy to sell you these, loads of tread left.
    I ran them on a 7 inch rim no prob but would be better on an 8.
    For the strip i have great respect for the m and h tyres from the states.
    Cheers
    Oct 2007
    Re: Slicks anyone..
    might be worth trying then eh see what happens next year when i eventually get my car to strip or track
    quote stuart clark,
    Hi,
    Cheers
    hi, the m and h tyres is what it will probably be, good reports all round and the !/4 mile chart shows
    got for free so might stick on ebay or see whatthey cann do for a moment of madness.
