Page 2 of 2 FirstFirst 12
Results 51 to 58 of 58
  1. #51
    Non-member gimme5's Avatar
    Dec 2008
    north yorkshire
    Re: my 306 dirty derv project
    should'nt be going over 10% thinners 5% fine,the more thinner you add the more it speeds up the evaparation time which results in the paint dulling off,other factors for dulling off are
    1 to fast a hardner
    2 to higher a pressure on gun
    3 spraying in cold
    4 to much heat while spraying
    5 soaking into primer
    6 not allowing paint to flash of between coats
    7 incorrect fan setting on gun
    8 gun been held to far back from car
    9 poor air movement
    10 to high of grade sanding used on primer
    11 to much material on car
    12 use of aeorsal primer
    i could go on and on and into detail but dont want to bore pants of you
  2. #52
    burton on trent
    hehe funny you say that last night we were discussing it..
    I think chances are
    Spraying in cold
    to much material on the car, and for some reason my gun was playing up and wouldnt give me a wide spray pattern..
    Next time hey :P
    thanks though i take all advice in
  3. #53
    Dec 2008
    north yorkshire
  4. #54
    Tipton
    Quote Originally Posted by gimme5 View Post
    1 to fast a hardner
    3 spraying in cold
    9 poor air movement
    13 you are no good at spraying - don't give up the day job.
  5. #55
    burton on trent
    indeed there is that.. although it comes up quite well with a very quick flat/polish, the geezer at bodyshop used a bit of paint to do a panel this morning and has had the same problem, he seems to think its just down to the paint being cheap jawel spec bull crap, i guess you buy cheap you get cheap.. In future ill stick to standox, had no issues spraying with that stuff
    you can see in this pic, i grave the corner of the roof and rear 1/4 a very quick buff and it came up ok
  6. #56
    burton on trent
    Had a busy one today, repainted the grill to freshen it up
    also flatted dwn most the car and polished.. still need to do passenger door, boot and rear bumper.
    Also fitted my wind deflectors
  7. #57
    Looks like its polishing up well mate
  8. #58
    burton on trent
    ive finally finished flatting the full car, and then gave it its first clean today ... I have also done the grill just just waiting on 2 clips before i fit it .
    Little update, i finally cracked out the tigerseal and began putting the missing bits on.
    Check out what i used to weigh the top of the spoiler down
