Results 1 to 26 of 26
    Non-member i l k e r's Avatar
    Cyprus
    Strange problem, car won't boost....
    hi all,
    I parked the car about a month ago and haven't started/driven it until today.
    It started the first time and it idles, revs and drives fine but it won't boost beyond 6-7 psi even though it's set to run 18psi.
    when it reaches to 6-7 psi there is a whinning noise much like a wheel bearing whinning and it won't boost beyond that even though the revs keep raising
    any ideas???
    Dublin/Ireland
    Re: Strange problem, car won't boost....
    sounds like a leak!
    Cyprus
    I thought that too but it was perfectly fine when I parked it. And all the hoses and vacuum tubes are new.
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    fetch the air filter off and have a look at the compressor wheel, make sure that it hasn't sucked anything up and snapped/bent a blade, then check for play. a leak does seem like the more likely thing though.
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    bare in mind that the leak might be in the form of a duff dump valve, or a hole in an intercooler, or a perished carb-top O ring, etc etc.
    Cyprus
    I already did that and it's fine. time for a leak test then
    thanks for the input guys.
    Cyprus
    none of the above I don't think but could this be actuator related do you think Chris?
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Quote Originally Posted by i l k e r View Post
    nah, not likely. you have to wonder what is causing the noise.
    other ideas off the top of my head:
    stuck choke flap
    throttle not seeing 100%
    air filter occluded
    wastegate penny in turbine has slipped, or is sticking open
    random leak elsewhere in boost circuit
    Cyprus
    stuck choke flap
    -removed
    -it wouldn't rev all the way down if that was the case??
    air filter occluded
    -tried filter off, it's the same
    -checked it's fine
    -will check and report back
    ahh the joys of C1J
    Cyprus
    running out of the ideas I took the compressor housing off and one of the blades is slightly bent
    I'll try and straighten it and see how it goes
    Non-member Adam L's Avatar
    Feb 2003
    SW London
    Remember those fins are very deilcate, there's a good possiblity you've bent it yourself taking the housing off.
    Cyprus
    Quote Originally Posted by Adam L View Post
    I know Adam, good care taken whilst taking the housing off...
    I've already straightened it and put it back together, time to put it back on the car and test drive
    Cyprus
    right this is getting ridiculous now.
    tried to pressure test the system for leaks today and the strangest thing has happened.
    as I try to pressure the system it feels like I'm trying to fill the void, air enters through the compressor housing and it vanishes. I couldn't even put 1psi into the system.
    there seems to be no leaks, so the only thing I could think of is a huge crack in the exhaust housing letting all the air out before I can pressurise the system.
    ideas please
    Oct 2007
    costa del walney Island NW
    Cyprus
    no cracks on the turbine housing.
    don't know what to do now.
    any ideas people?
    Did you block the inlet on the turbo whilst doing the pressure test?
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    Do you have the original exhaust recirc pipes on and anti perc fan? sounds like you may be sending pressure down to the perc fan causing a whining noise? The valve can be prone to sticking/failing. Not sure what your problem is when your pressurising the system? how are you trying to pressurise it?
    Member clee's Avatar
    Derbyshire
    You have sealed the intake off right ?
    Cyprus
    pressurising the system from the turbo intake so that's sealed.
    no anti perc fan or any other std. unwanted pipes etc.
    Compressor housing sealed to the backing plate properly?
    Cyprus
    yes mate it definetly is.
    Strange Are you using a compressor to pressurise the cct? Must be able to hear a leak that big?
    Cyprus
    strange ain't the word my friend. Yes I'm using a compressor to do the test and it doesn't sound like ther's a leak. It feels like it keeps filling with air.
    I think I'll remove the whole boost circuit off the car and try it that way
    Sep 2005
    Parkgate Cheshire
    what intercooler do you have? if its the gt tuning breadbin one, they have a tendecy to be battered by the clutch release arm. mines popped a couple of times there, definetly sounds like a boost leak tho.
    Cyprus
    problem solved
    I took the bumper off to have a butchers at the i/c piping then realised there was a snapped jubilee clip, but because it was stuck on the silicone it wasn't visible. Changed it, put the bumber back on and it's all back to normal now
    thanks for all the input
    Non-member raj's Avatar
    Feb 2001
    Rohtang pass
    problem solved
    well thats yours sorted, just mine left now
