Results 1 to 23 of 23
    Non-member allanr5gtt's Avatar
    Dec 2008
    the carport
    lm-1 log works
    need abit of help people in the no
    ive found this log works and its all smooth on the graph, sum up and down but you can generally work out a clear line
    http://www.97supraturbo.com/EBV%20Mo...ost%201JPG.JPG
    where as mine is like a picture of the swiss alps , i would post mine up but it wont allow me, error 09 i think unable to upload
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: lm-1 log works
    it should smooth out once you're at full throttle. part throttle readings from a carburettor will be a bit weird looking.
    try uploading it to the files area instead of the forum
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: lm-1 log works
    ah, I forgot, you are EFI. In that case, the part throttle readings will only be as good as the mapper. Or, if the readings show overly lean patches it might be that you are not getting enough gas across the sensor, say if it were in the tailpipe.
    Dec 2008
    the carport
    Re: lm-1 log works
    no mate this one is on my carb c1j not the efi 1
    Dec 2008
    the carport
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: lm-1 log works
    it's a bit lumpy aint it
    where is the sensor mounted ?
    does the display on the LM-1 show the same lean readings as the log ?
    what happens at full throttle ?
    Dec 2008
    the carport
    Re: lm-1 log works
    i'm glad some one can open the file
    the senor is about 6-8" from the back of the turbo.
    the lm1 shows some sort of 20.1 o2 reading (between 20.1 - 20.5 o2)
    some of that log was full throttle (about half where though)
    i might take another log and see what happen's? what the best where in take a log? ie full throttle four gear or would 5th be better?
    thanks allan
    Dec 2008
    the carport
    Re: lm-1 log works
    Quote Originally Posted by allanr5gtt View Post
    thanks allan
    the plugs and senor are telling me it's rich very heavy black soot?
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: lm-1 log works
    I think something is intefering with the sensor then, because the reading should never go as high as that.
    make sure that the cable is as far away from the HT leads and AEI module as possible. try routing the cable round and out of the bonnet, and in through the door, etc.
    regarding it being rich, the other thing that will make the O2 reading look lean is a missfire. is the car missfiring a lot ?
    Dec 2008
    the carport
    Re: lm-1 log works
    the car pull strong as a ox. doesn't miss a beat smooth and strong all the though the rev range. i will try moving the leads and do another log thank for the advice
    Non-member rs250nut's Avatar
    Re: lm-1 log works
    So true, this is what fecked me up at the pod being 5psi down on boost, and I did not get to the bottom of it until months after.
    Dec 2008
    the carport
    Re: lm-1 log works
    right i did a few logs today and the logs were alot cleat after moving the senors lead away from the ht lead and aei unit. thanks chris for your help.
    hope you can see the new logs as for some reason i cant? permission denied?
    https://www.rtoc.org/files/?path=Tech...s/Log%20Files/
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: lm-1 log works
    yes, log looks fine to me, it will have been HT noise intefering with the sensor lead
    it doesn't look like you have RPM hooked up yet, but it looks to be getting leaner as the revs increase. 13.2:1 is a bit high for anything over 1 bar of boost I'd say. maybe try a smaller air corrector
    Dec 2008
    the carport
    Re: lm-1 log works
    ok just been out a did another 3 logs the 1st one is from low down in 4th gear and in2 5th til bout 6k ish, the 3rd log is from low down in 5th. i back off in 5th just after 5000rpm as there was a strange noise on the det cans and it shows on the log?
    as for the rpm reading, is this another box of tricks i have to buy for the lm-1 or is it simply something i have to enable to show on the logs ?
    https://www.rtoc.org/files/index.php?...s/Log%20Files/
    Re: lm-1 log works
    Did you make the det cans yourself?
    Dec 2008
    the carport
    Re: lm-1 log works
    yeah made them myself just a cheap set but better than nothing tho. i find them quite interesting to listen to.
    i hope this help you a bit mate
    https://www.rtoc.org/boards/showthread.php?t=11652
    http://www.tooled-up.com/Product.asp...ferrer=froogle
    Re: lm-1 log works
    Top job mate. I cant wait to get the car back together as I have loads of bits and pieces to piss about with
    Feb 2009
    colne lancashire
    Re: lm-1 log works
    you dont drive round with a stethoscope in do you???? lol
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: lm-1 log works
    Quote Originally Posted by jonnyshaw49 View Post
    yes, that's how you monitor for detonation.
    Feb 2009
    colne lancashire
    Re: lm-1 log works
    im sure you can get led sensors with lights on and beep tones to help you find detonation problems. or is the stethoscope most accurate??
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: lm-1 log works
    sthethoscope is a bit oldskool, but the prefered method for a lot of tuners. the electronic knock-link and the like can be hit and miss, and need setting up with each different engine they're connected to.
    Dec 2008
    the carport
    Re: lm-1 log works
    i have been looking in to log the rpm and afr and as far as i can work out that i need the lma-3 to log engine data. am i right?
    http://tunertools.com/proddetail.asp?prod=IN-3742
    can any one apart from scoff see my logs? (as i cant once after i have uploaded to the rtoc file)
    North East Regional Rep HULK's Avatar
    Aug 2009
    harrogate, North Yorkshire
    Re: lm-1 log works
    you can sometimes pick a decent knocklink up on eBay for about 60 quid
