Page 4 of 6 FirstFirst 123456 LastLast
Results 151 to 200 of 271
  1. #151
    Non-member Fordy's Avatar
    Aug 2010
    Cambridgeshire
    Re: my ginger mobile, from start to present... pic heavy!!
    you need to run more fuel through it fella 12.3 is only just safe on most injection turbo engines.
    I'd be down into 11.8-11.5, you will loose a max of 10hp but your pistons will be much happier in the long bike chasing runs
  2. #152
    South Wales
  3. #153
    Non-member markey b's Avatar
    Bury St Edmunds
    looks a bit posh, mappable ignition will probably be my next step once i've remorgaged for a VNT overhaul
  4. #154
    Bury St Edmunds
    update is...... its still sleeping
    on the plus side, the new toy arrives tomorrow...
    its only 110bhp
  5. #155
    Bury St Edmunds
    slight update... after its slumber since aug 2011, finally got it out the garage friday night, got it up to the unit and replaced the starter and clutch cable, then got it MOT'd on sat
    needless t o say it sailed through, so just need to tax it ready for the nice weather
    bit smokey and my turbo needs a rebuild so thats going to be next on the list
    only problem i have now is that i'm spoilt for choice when the sun is out.....
  6. #156
    Bury St Edmunds
    30miles so far this year... then booom!
    new head to go on, and this, and a few tweaks for 2012
  7. #157
    Non-member Coops's Avatar
    blummin heck you chew through a few engines
    F7P turbo time
  8. #158
    About time you set it up properly aint it lol
  9. #159
    Bury St Edmunds
    just liners not engines
    overskimmed head is finally being retired, found split coolant pipe and no mixture screw which i think helped it die, also retarded the ignition timing and i'm gonna swap the TDC leads over to make up for less advance..
    should be back and running again in a few evenings and wonder how far i'll get this time, and as for F7 turbo... naaaaa
  10. #160
    M
    Mark doing all that will help but you seriously need to monitor for det
  11. #161
    Bury St Edmunds
    Quote Originally Posted by Finch View Post
    M
    and a little less boost for time being until i get some EFI or mappable ignition
  12. #162
    Nov 2010
    Burntwood Staffs
    dude.. you are a living ledgend
    how many times have u blew it up? fair play for keep going back to it.
  13. #163
    norwich
    about time mr B
    maybe invest in a digital/twin port boost controller for the spike issues and start measuring inlet temps/egt's your pushing way to much boost for
    " best guess tuning"
    or if you want more reliable 230-300 bhp then start again with more capacity, like the b18f/f7 engines
    after the 3 or 4 blow ups you have had, the c1j rebuilds would have paid for a bigger /better engine set up ie oil sprays under the pistons and fuel injection, and no liners to split, that said get it wrong on the above renault blocks and you can start spending money
    your call
    might be up and running in another month or so( depending on how much longer helix can piss about making my clutch) anyway could pop over and tempt you to the join the f series club, its catching
  14. #164
    Bury St Edmunds
    i can see what your saying but the power delivery of a C1j is unlike any other, and i dont want it to loose its savageness, thats what makes it fun
    liner replaced last night, just got to put valves in the new head and put it all back together
    thought id sort some of my carbon bits too, as they had been attacked by the UV light
    before:
    after:
    just need to put some 2k lacquer on to gloss them up a bit
  15. #165
    Does this mean ginge will make an appreance at Blyton Park?
  16. #166
    Bury St Edmunds
    nope, ali's birthday
  17. #167
    Tell her, her mother lied and she was born on the 29th
  18. #168
    Bury St Edmunds
    u tell her that hero! lol
  19. #169
    F**k no lol
  20. #170
    Non-member r5 rich's Avatar
    Romford, Essex
    when you going to sell it to me then, it matches my hair pefect
  21. #171
    Bury St Edmunds
    Quote Originally Posted by r5 rich View Post
    i'll sell it when u make me a tidy offer
    *cough* E46 M3 *cough*
  22. #172
    Bury St Edmunds
    spent a couple of hours on it yesterday and got new head built up. remembered how much of an arse fitting uprated valve springs with a 16v tool is...
  23. #173
    have you been in a high boost F7P motor? if you think a pokey 200 odd bhp C1J is savage try a fastchipped laggy F7P fella, believe me it brings a whole new meaning to savage when it spools up
  24. #174
    Quote Originally Posted by Coops View Post
    I am with Coops, about time you changed to the F7p
  25. #175
    Bury St Edmunds
    i didn't mean they were slow, i meant with a VNT on a c1j starts spooling at 1500rpm hits 27psi by 3000 and pulls to the limiter at 7k, spins up in 5th in the dry by stabbing the loud pedal
  26. #176
    South Wales
    I think im going to have to get a passenger ride in a c1j with a VNT before I decide on my next turbo
  27. #177
    Member
    Turn The Log tuning
    bigdur's Avatar
    Mar 2011
    Malvern
    My wifes birthday on the 28th too.
  28. #178
    oh no I know you didn't mean that mate, its not the speed I thought you we're on about, its the delivery, the F7P on a pikie chip provides a very brutal power spike as it comes on boost, its a right giggle! I know mine aint slow, 12.3 1/4 mile on road tyres shows that, I wasn't talking about outright power
  29. #179
    burton on trent
    for me the appeal to the c1j is..
    • the fact its 1.4 and sounds like a tractor,
    • the fact when you open the bay you cant see the engine, just stuff all around it.
    • and the fact that most jobs can be done without removing the engine.
    If i was offered another one on a plate for minimal cash id take it.. but until that day im happy to stick with c1j
  30. #180
    Bury St Edmunds
    little bit more done last night... just cooling system to finish and boost pipes etc.
    turns over with good oil pressure, also want to do some wiring so will do it thurs eve all being well
    Finally put a feed pipe onto the ducts, mounted to the car itself so stays in place when bumper is removed, and lines up with duct when bumper is on. currently just an extra air feed to filter may use it for wastegate if i get heat problems in the bay
  31. #181
    Non-member gttjames's Avatar
    Cambridge
    looking good mark
  32. #182
    Does this mean it'll be on the road before Christmas?
  33. #183
    Bury St Edmunds
    try this eve
  34. #184
  35. #185
    try this eve
    About time
  36. #186
    Bury St Edmunds
    well, its apart again, had a rattle, couldn't find it in situ so engine out and stripped again
  37. #187
  38. #188
    Noooooooooooooo I feel for you matey , were was the rattle from top end, bottom?
  39. #189
    Bury St Edmunds
    sounded like top end, but with rocker cover off sounds like bottom, but flywheel end?! needs to be stripped and checked and done properly i guess
  40. #190
    But your idea of properly differs from everybody else's, namely "ah that'll do, chuck it in and wined the boost up"
  41. #191
    Bury St Edmunds
    That's because if you spend too much time and money it's only a waste when it pops again. I think fuelling is what keeps breaking it, ive never ever had mechanical failure of an engine I've nailed together...
  42. #192
    Non-member TNT ANDY's Avatar
    Gutted for you mate
  43. #193
    Bury St Edmunds
    Thanks to mr mad andy my cam is now at 113deg rather than 120odd lol
    Hopefully have bottom end in this eve, just waiting for mls gasket to land. Already changed gearbox oil with elf stuff just brake fluid change and few odds and sods
  44. #194
    Fingers crossed for you what was the rattle in the end?
  45. #195
    Bury St Edmunds
    No idea but I've checked anything expensive so if it still rattles I'll wear ear plugs and ignore it lol
  46. #196
    Bury St Edmunds
    and.....
    its running with no knock... no idea what it was but its gone
  47. #197
    and.....
    Fingers crossed it makes more than 30miles
  48. #198
    Bury St Edmunds
    who knows?! lol
  49. #199
    Good work fella. NOw get it ts here for a viewing.
  50. #200
    Bury St Edmunds
    will do fella, just not on a school night
