Results 1 to 26 of 26
    Trader
    GT Turbo Spares co.uk
    South East Regional Rep
    phase i 16 v turbo's Avatar
    Jan 2001
    Morden
    C - Reg Phase II HOW????
    Ok, silly question time. From memory the Phase I was released on a C and D reg, The Phase II was released on E – J with the old K reg. How is it possible to get a C reg Phase II, it isn’t on Irish plates or on a private plate?
    Many thanks for any help that can be offered.
    Non-member BriC's Avatar
    Dec 2005
    Re: C - Reg Phase II HOW????
    It isn't? Is it one you've seen? Are you sure it hasn't just had a phase 2 kit put on at some time?
    Trader
    Jan 2001
    Morden
    It has Phase II Shocks, Decals, Cooling system, Complete Interior, Centre Console, Body kit, The tag on the bulk head is the Phase I type not Phase II. One Elderly owner from new. It has not been resprayed. I spent hours looking for any tell tell signs that it has been changed from a Phase I to a Phase II. I am going to go back and have another look today.
    Dec 2005
    Wierd.. Where is the ECU?
    Non-member raj's Avatar
    Feb 2001
    Rohtang pass
    Quote Originally Posted by BriC View Post
    that would be located under the bonnet bric! please do keep up
    Please tell me where the ECU is I know where the AEI is
    Dec 2005
    Eh?
    Phase one it's in the engine bay area, above the turbo, phase two, it's in the bulhead area.
    Dec 2005
    AEI is what I meant
    Non-member Tiny Tim's Avatar
    Oct 1999
    Bournemouth
    Most E reg cars were 'phase 1.5' so had a mish-mash of ph1 and ph2 bits.
    If it looks like a phase 2 car and has a C-reg plate its simply one of two things...
    1) A private plate of some description
    2) A phase one thats been converted
    Dec 2005
    Private plate.. Totally forgot about that
    Trader
    Jan 2001
    Morden
    In my first post I did write it is not on an Irish plate or a Private plate. The AEI is a 209 in the black box behing the bulkhead. It must have been converted, but what other things can I look for apart from the bits I have listed. The tax discs have the C reg on it all the way back.
    Thanks
    Might have been reshelled at some point with new parts? New parts added for the newer look? Or possibly a ringer Get some pics up for us to have a look at.
    Chassis number, engine plate, whats the reg on the car? all the rest is just visual/easy to change.
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    Conversion is the only logical answer.
    I'd imagine a ph2 version of the gtt was still only on the Renault drawing boards back in '85.
    Trader
    Jan 2001
    Morden
    This confirms it is a Phase I and that reg is correct. I will get some photos when I go and have another look later.
    Non-member tonesGTT's Avatar
    Aug 2000
    There you go then mate, its a look a like phase II. Dont wish to be negative but why would someone go to all that trouble and expense unless, maybe, the car had been in a shunt???? Cynical, but not unrealistic. Have you been all over the underside yet? What are the panel gaps like?
    I take it the one elderly owner isnt selling the car then? Would have been interesting to hear what they had to say about its history?
    Trader
    Jan 2001
    Morden
    I will be meeting the elderly owner this evening as it was one of his sons last night, but it all looked straight enough from underneath. When you open the door it is like time has stood still although it is Phase II interior it is spotless. 40K on the clock and I will look at the service tonight. Someone has spent alot of money and time making this into a Phase II. The engine bay is very clean.
    Trader paul b's Avatar
    Jul 2002
    chassis number should start VF1C405
    the oval plate should be near the brake master cylinder.....
    country code number should be 600 if its phase although it could have 720 ......
    not much more I can tell you without chassis,oval plate and reg numbers
    Trader
    Jan 2001
    Morden
    The chassis number does start VF1C405
    But the country code number is 500 unless I have read it wrong.
    Thanks for the advice will double check this evening.
    Cheers
    Trader
    Jan 2001
    Morden
    Got the full story last night, yes it is a Phase I, the chap that owned it was an ex service manager at Renault dealership. It was converted at work. So everything was done even the fuel filter setup etc. Not the best pictures but will give you an Idea, as it was cold and wet out this morning. Low mileage 40K. I am going do the head gasket this weekend, so will give me a chance to look inside and see!!
    Oct 1999
    Bournemouth
    Still got phase 1 mirrors and vinyl door cards by the looks of it.
    Still, nice little project to keep you busy.
    Aug 2000
    Nice one! What the hell happened to the steering wheel
    Trader
    Jan 2001
    Morden
    Quote Originally Posted by tonesGTT View Post
    I know I have already dug out a a Renualt one!!! Yep will keep me out of trouble for a few weeks. Someone has tried to pop the driver's side door lock, pain and it has gone on the A post in the bottom corner.
    Non-member UNICRONICUS's Avatar
    Jun 2004
    Isles of Scilly
    Erm....FAIL?
    Non-member Russ B's Avatar
    Aug 1995
    Colchester (Brightlingsea)
    There are other tell tale signs to see if its a phase 1, most of the plastic interiour parts have date codes on them. The fuels tanks also have date codes that you should be able to see if you look through the o/s rear wheel arch, if its an original C plate i'd expect them to be 85. Also the chassis number should be stamped as "whole" numbers & letters, not made up by dots. There are other minor differences that the trained eye can find. Worth a look.
    Trader
    Jan 2001
    Morden
    Many thanks!
