Results 1 to 14 of 14
    walsall
    i own pepe
    just a little hello to 21 owners
    been around with 5's for awhile but my 1st year with a 21 and love it apart the sunroof
    £150 from renault and still leaks
    Trader paul b's Avatar
    Jul 2002
    Re: i own pepe
    good man..........
    chaeck the drain tubes are not blocked......stiff wire or a welding rod with tape on the end....1 on each corner...if they are blocked she'll leak like vicars choir boy
    I likes 21's....
    Non-member Tiny Tim's Avatar
    Oct 1999
    Bournemouth
    Re: i own pepe
    Top choice mate, I know Roj and Sarah looked after that car.
    Might also be worth checking the seal when its closed - especially if either the back or front of the sunroof is closer to the bodywork than the other as they're SLIGHTLY adjustable... you may just have it 'off-centre' slighty. But as paul says... drain pipes first.
    Jul 2002
    Re: i own pepe
    don't listen to this CRACK head.......
    he's BLEEDING mental,,,,,,,,,off his BLOCK I'm sure....
    Oct 1999
    Bournemouth
    Re: i own pepe
    He was Tiny Tim. The world will remember him by another name...SCARHEAD
    Jul 2002
    Re: i own pepe
    a man, barely asleep.......ooops, I mean alive.....
    Oct 1999
    Bournemouth
    Re: i own pepe
    Mate, you dont know how right you are... the wife decided to give us both food poisoning on Monday night.
    Member clee's Avatar
    Derbyshire
    Re: i own pepe
    Welcome to a mans world fellow 21'r
    We all have to grow up one day ................Trouble is I think I'm regressing .......
    walsall
    Re: i own pepe
    was thinking it was off centre as its leaking from the rear edge and not the front. going to look at it when its stays dry
    Oct 1999
    Bournemouth
    Re: i own pepe
    Quote Originally Posted by bye_all_c_ya View Post
    Thats where the seal itself joins if I remember correctly. I take it that £150 you paid Renault was for new glass AND seal?
    walsall
    Re: i own pepe
    yep ive got the tilt and slide and the glass and seal as one unit inc vat
    Non-member rogerreno's Avatar
    RC Racing HQ
    Re: i own pepe
    Did Renault forget to tell you that?? They leak as standard....
    I wouldn't bother taking the roof out coz all the drain tubes are fitted to the corners and they're all clear...I know coz I refitted them when I repaired the sunroof assembly (the cables were seized).
    The roof shuts straight and even if it didn't, it wouldn't matter because the glass fits inside the sunroof tray assembly and this is sealed, so any water getting in would just collect in the tray and run out of the drains.
    I have a new glass (slide and tilt) fitted to BOB that came from Renault at a ridiculous cost a couple of years ago and it still leaks (and this is the 2nd one they supplied because ...you guessed it, the 1st one leaked!!)
    They leak between the seal and the glass and theres nothing you can do about it
    Soz mate...anyway, are you looking after my baby???
    walsall
    Re: i own pepe
    yes mate apart from intercooler no issues lol
    still looking for a intercooler if you now of one, fmic would be nice
    bracknell
    Re: i own pepe
    geting the inside of a french bitch wet. i can do that or used to be able to do that
    now all i get is dry
    sorting out a sunroof is easy
    the trim between the glass and roof is not a seal . a good fitting roof does help
    there are 4 drain tubes on each courner of the main frame each of the tubes has to drain as fast as pos or a backup wil occure.
    the next thing im gonna say might seem stupid but water will caplierise through the fitting
    on some sun roofs fitted to renys . renault used a foam seal (bit like a draft excluder strip thingy)
    to solve the ingres of water via the sun roof
    clean out all the drain tubes
    lower the sun roof assy
    remove the OE foam seal
    replace the foam sealing between the s/r and the body/roof with an impermable water but flexable sealent
    jobbs a goodun innit
