Results 1 to 12 of 12
    Non-member Nick13's Avatar
    Aug 2009
    Chesterfield
    Another Doozy!.........keys thrown away!!!!!!!!!!
    Another cow of a problem, and hey, for once it isn't my fault!!!!!!
    This is a good Un..........
    My elderly mum has thrown my keys out with some rubbish and the bin men have been!....................
    I can still get in and out with my spare fob..............but if anyone's got any ideas how to get round this one I;d love to hear from you!
    Twenty year old car, no ruddy key...............I have no idea what to do now.........Help!
    Non-member car.crash's Avatar
    Aug 2006
    Re: Another Doozy!.........keys thrown away!!!!!!!!!!
    i feel your pain.
    Aug 2009
    Chesterfield
    Looks like the good old screwdriver method......................Damn!
    Non-member alex barker's Avatar
    Jul 2006
    drivers door lock and ignition barrell change is the only way out. OUCH, my mate got a 21 turbo given 2 him wid no keys and he bought a new door lock and go a barrel from a 5 and fitted that. and it worked joy. hope this helps
    Aug 2009
    Chesterfield
    Quote Originally Posted by alex barker View Post
    Hey, it's a start mate..................Everytime I so much as think about that damn car it costs me money!......
    theres a barrel and key on e-bay at the mo........looks like it came out of a proper wreck though!
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    Drop Mike (gtt spares) a PM, and he'll sort you out with an ignition barrel & key(s).
    Tipton
    you can remove the door locks easily once you have removed the interior door cards.
    the ign lock....if you remove the steering wheel, the lower cowling and undo the 4 bolts/nuts to drop the whole column down, then drill the two lugs that hold the ignition barrel in place, undo the small screw under the ignition barrel. then lever the barrell and the wiring out the top.
    To be fair mate, it wasn't your fault, get it fixed and bill ya mum for the parts
    Aug 2009
    Chesterfield
    It's de-locked, well the doors are...and I've got a spare fob...........so could get away with a barrel and key for now...........when I've put a new turbo oil feed pipe on......then I can start it.....take it to my mates and we can drop the sump again and try a bit harder with the gasket this time!
    I know what happened with the one thats on, my mate fancies himself as a bit of a mechanic, and in his wisdom, he decided not to bother with one of the rubber end seals that are part of the sump gasket set, making do with silicone instead........hence leak!
    To be fair though, the original, oil leak free sump that we took off in the first place had no gasket at all and was just silicone sealed, with no leakage whatsoever.
    Guess there's a knack to it..........
    Non-member GTphil's Avatar
    Yup Use a **** load of sealant and I mean a **** load, and make sure you tighten the bolts progressively
    Also use the sealant on the moon shaped seals too
    Aug 2006
    or use a cork gasket.
    Aug 2009
    Chesterfield
    Will do mate,
    thats where we boobed.........didn't do the progressive tightening........just let it go off and tightened it up..............
    It's not that bad really, just the odd drop, but I can't stand leaky cars.............you can imagine how great I felt when the tubo oil pipe let go..........jeez......there was a "bit" of oil flying about mate!!!!!
